And the Nice Thing About a BIG Turbo Is . . .
Old Jun 27, 2006 | 05:06 AM
  #31
Ted B's Avatar
Originally Posted by RREvo
Hey Ted what Clutch are you currently running?
I'm still using the stock clutch, which is why I'm limited to 25 psi for the time being.
Old Jun 27, 2006 | 06:53 AM
  #32
Event-Horizon's Avatar
Get the Exedy twin disk heavy duity if you can, its a great clutch and easy to drive.
Old Jun 27, 2006 | 07:00 AM
  #33
Ted B's Avatar
I'm considering that one, as well as the Tilton.
Old Jun 27, 2006 | 01:34 PM
  #34
Vishnu_Evo8's Avatar
i 2nd the motion for exedy twin disk hd. I have been using it for a bit ad it works great. Much less chatter and it holds well. Or if you want the rolls royce of clutches, go for the tilton tripple carbon, but be ready for a 3k plus price tag.
Old Jun 28, 2006 | 05:00 PM
  #35
IE Evo's Avatar
[QUOTE=Vishnu_Evo8]i 2nd the motion for exedy twin disk hd. I have been using it for a bit ad it works great.
Been using it a bit. Oh so u have 2000 miles on it and it has not failed. LOL! You go through clutches like Smoggy goes through Beer,I go thru Burgers,Dustin goes thru crack,and Al goes thru DB motors.
Old Jun 28, 2006 | 06:50 PM
  #36
shiv@vishnu's Avatar
Old Jun 28, 2006 | 07:24 PM
  #37
RenoEvo's Avatar
[QUOTE=IE Evo]
Old Jun 28, 2006 | 09:27 PM
  #38
madpacket's Avatar
Ted B is my hero. I want a car like Ted B !
Old Jun 28, 2006 | 09:42 PM
  #39
sell your sti, buy an evo 9, add a stage 2 kit or any turbo upgrade with at least a 30r and you will have almost that much power for very cheap.
Old Jun 29, 2006 | 11:17 AM
  #40
Ludikraut's Avatar
Ted, what is your useable powerband with the 35r on the stock block?
l8r)
Old Jun 29, 2006 | 11:24 AM
  #41
scorke's Avatar
^ I am going to assume 4k-8k.
Scorke
Old Jun 29, 2006 | 11:31 AM
  #42
Ted B's Avatar
A little extrapolation of the power curve and calculation of optimum shift points tells me I need a 1-2 shift point around 8800rpm, and around 8500rpm for the rest. Obviously, it isn't wise to attempt that with the stock block and valvetrain (I'm limited to 7800rpm), so I'm putting together something a bit more robust.
Old Jun 29, 2006 | 11:43 AM
  #43
Ev0ikon's Avatar
I would hate to run in to you on the freeway. One of these days I'll have my car like yours :P
Old Jun 29, 2006 | 11:45 AM
  #44
Ludikraut's Avatar
Scorke
I would be very impressed if he got full spool by 4k with a 35r.
Hmm, so will he go with a built 2.0 or something bigger? I can tell you that the 4g63 sounds pretty insane as it approaches 9K.
l8r)
Old Jun 29, 2006 | 11:53 AM
  #45
Ted B's Avatar
Then just avoid I-65 between B'ham and Decatur after 6pm.
That's remains a question at this point, but I've ruled out a long stroke motor entirely.
