Vishnu Ohlins are here!
Old Jul 19, 2006 | 05:30 PM
  #46
Tristar's Avatar
Heres a question. It seems in Japan the trend is to use stock sway bars with high spring rates to help rotation. Are these coil overs designed to work in conjunction with an aftermarket bar, or was development done based on the stock sway bars being part of the package. I honestly would like to stay away from the compromise of a large bar at higher speeds ad this setup,; if designed for the stock bars, would definately be a purchase for me...
Old Jul 19, 2006 | 05:33 PM
  #47
meanmud's Avatar
If I may, it's designed for the stock bars
Old Jul 19, 2006 | 05:39 PM
  #48
Tristar's Avatar
You may, as long as your correct...
If thats the case, I have found my suspension answers. Any more pictures of them mounted on the car? Plus the ricer in me just has to see the static ride level...
Old Jul 19, 2006 | 05:41 PM
  #49
chronohunter's Avatar
get your check book out
This kit was designed and tested to work with stock front and rear sway bars
If someone has to have upgraded bars we will do custom "between stage" combos that feature upgraded front and rear bars (matched set) if desired as well.
The kit does include urethane bushings for the stock sway bars (which helps responsiveness). Check out the first post for the full list of bits and pieces
Old Jul 19, 2006 | 06:10 PM
  #50
meanmud's Avatar
a few crappy pics:
Attached Thumbnails Vishnu Ohlins are here!-frntcnr.jpg   Vishnu Ohlins are here!-bckcrnr.jpg   Vishnu Ohlins are here!-evoside.jpg
Old Jul 19, 2006 | 06:34 PM
  #51
Dustin@Vishnu's Avatar
Old Jul 19, 2006 | 06:52 PM
  #52
Djazair's Avatar
More information is available in these threads, the second is really long but worth reading.
ultimate suspension engineering
Vishnu Ohlins Gerrard Spec setup
I will try to answer as many technical questions as well.
Old Jul 19, 2006 | 07:00 PM
  #53
Originally Posted by DaWorstPlaya
Finally!!! after a wait of 2 years!!! ... Just wish I could ride in someone's car that already has this setup, so I can make up my mind. So tempting
Everyone we have sold them to are so proud of them that they all offer rides . If you're ever in Denver you can rip mine up the canyon anytime
Old Jul 19, 2006 | 07:03 PM
  #54
This may be the route I take. Paul, we need to get together soon!
may be at PMI on Wednesday the 26th (next week)
Old Jul 19, 2006 | 07:10 PM
  #55
Event-Horizon's Avatar
ooooo, this would be a good setup for the tail of the dragon. So tempting....
Old Jul 19, 2006 | 07:18 PM
  #56
I have ridden that on my sport bikes and I would agree
Old Jul 19, 2006 | 07:52 PM
  #57
Warrtalon's Avatar
Paul, be sure to let me know via PM. I will take the day off from work and drive down there for some practice and to learn some things.
Old Jul 19, 2006 | 09:28 PM
  #58
donour's Avatar
I'm pretty sure i'm a go for this as long as Gregg is going to make the trip.
I am so not going to pass my PhD exams in august. :-p
d
Old Jul 19, 2006 | 09:36 PM
  #59
Warrtalon's Avatar
Donour, you're coming from Albuqerque for just a weekday open track session? Is there an occasion? I'm going, because it's 35 miles away.
Old Jul 19, 2006 | 09:39 PM
  #60
we were going to do a coaching day but now it looks like a test day for myself and Joe
