Track Wheels for a 9 MR
Old Jul 21, 2006 | 08:21 AM
Atlmethevo's Avatar
Okay I got my evo last night and need to find some track wheels. I dont care what they look like as long as they fit right and are the same size as stock. Please post your ideas.
Old Jul 21, 2006 | 08:25 AM
BigEd925's Avatar
5 zigen fn01r-c 17x9 +35 wider then stock, cheap, and strong.
Old Jul 21, 2006 | 08:34 AM
Atlmethevo's Avatar
What tire size would you run? Also I am going to be running a Toyo R1 or better race tire. Do you need spacers with these? Also what offset do you need?
Old Jul 21, 2006 | 08:36 AM
RazorLab's Avatar
you can run a 255/40/17 Toyo RA1 without any fender modifactions with those 5zigen FN01R-C 17x9's
Old Jul 21, 2006 | 09:00 AM
Jeff_Jeske's Avatar
I suggest getting another set of MR wheels and running 255/40/17 tires. That is what I am using and they are great.
Old Jul 21, 2006 | 11:21 AM
broeli's Avatar
You're better off running a little wideer wheel like 8.5-9" and running the 255's. You can run the stock rims with 255's but you won't get as could a contact with them as you would a 8.5-9" rim. I ran 255's on my stock rims for almost 2 years autox'ing and road course racing. Now I run 17x8.5 Enkei RPF1's and love them. They are super light and not all that expensive. I also run 17x8.5 Gram Lights with 245/40 A032r's as my street tire in the summer
BTW, the RPF1 will fit like stock eventhough it is 1/2" wider....as do my Gram Lights. No spacers and no clearance issues. If you're spending the money get something a little wider now or you might regret it later...
Old Jul 21, 2006 | 12:43 PM
Atlmethevo's Avatar
Sounds like good advice, do you happen to know the offset and such as well as the spacing?
Old Jul 21, 2006 | 12:52 PM
broeli's Avatar
The offset on my RPF1's are +40. On my 57c Gram Lights the offset is +30.
Old Jul 21, 2006 | 01:58 PM
Ludikraut's Avatar
Get a set of used stock rims. If you're patient you should be able to score a set for ~$400. Cheap, light and proven.
l8r)
Old Jul 21, 2006 | 02:35 PM
Warrtalon's Avatar
I wouldn't use stock Enkeis, because they weigh 20.5lbs. If you do, then drive those daily and use the BBS (17.7lbs) for racing. I currently use my stock BBS's with 245/45-17 V710s for racing and Rota Torque (same color/style and 18lbs) with 255/40-17 for daily driving + drag racing.
If you want stock size rims other than the BBS for racing, then maybe the Kosei T1 or whatever they are, since they're only 15.5lbs. I know someone here in CO selling a used set for $650 that have only been used to autocross. I personally need to find some 17X9s that are lighter than my BBS rims, but I haven't found any yet. Anyone know the weight of the plain ole FNO1RC 17X9s?
Old Jul 21, 2006 | 03:12 PM
RazorLab's Avatar
The FN01RC 17x9 are approx 19-20lb I believe. As much as people like to argue about wheel weights, I don't think +/- 3lbs is going to make a big difference at open track events.
Old Jul 21, 2006 | 04:13 PM
Ludikraut's Avatar
Like any of us here are good enough to require lighter wheels at the circuit. :shrug:
A pro like Chronohunter, I could understand, but the average Joe might as well save the $$$ and invest in more track time.
l8r)
Old Jul 21, 2006 | 05:08 PM
RazorLab's Avatar
Exactly my point Ludikraut.
Old Jul 21, 2006 | 05:22 PM
evobeaner's Avatar
how about these. 18" under 18 lbs.
oops sorry, these are not stockers but they do come in 17"?
Old Jul 21, 2006 | 05:27 PM
SuperHatch's Avatar
The overwhelming majority of wheel weight is in the rim itself, not the spokes or hub. Taking that into consideration, an 18" wheel that weighs 18lb may have more inertia than a 17" wheel weighing 20lb. Just something to consider...
