Octane booster.......
Old Jan 15, 2004 | 02:39 AM
BuLocal's Avatar
Question Octane booster.......
Shiv or anybody else........It seems the good stuff (higher octane gas) is getting harder to find, especially here in the Peoples Republic of California. I was wondering if it would be possible to use octane booster to run any of the higher octane maps. Has anyone tried this?
Old Jan 15, 2004 | 06:41 AM
psionic98's Avatar
that would probably work if you got the right mixture, but now you're talking about a ton more cash just to up your octane... but if you have the money, its probably very doable
Old Jan 15, 2004 | 06:56 AM
Remorseless's Avatar
Registered User
I hear that most of the boosters use various chemicals that can foul the sensors. Has anyone else heard this? Thanks...
Old Jan 15, 2004 | 06:57 AM
mifesto's Avatar
i heard octane boosters can clog the fuel injectors
Old Jan 15, 2004 | 07:42 AM
jbrennen's Avatar
If you want an effective, relatively economical, safe, octane booster, there is only one way to go... use toluene or xylene (they are pretty interchangeable as octane boosters).
Search these forums or the web in general for: toluene AND octane.
Old Jan 15, 2004 | 07:51 AM
tswift's Avatar
use toluene, it works. You buy it at the paint store. Cost about $30 for 5gal. The article I read said to put in 2-3 gal tolune per tankful. the link is on the site.
Old Jan 15, 2004 | 07:58 AM
mifesto's Avatar
adding toluene? theres gotta be some negative side efffect to that
Old Jan 15, 2004 | 08:01 AM
tswift's Avatar
according the article this is the same stuff they used in F1 years ago to get insane power out of small turbo engines. It is a hydrocarbon and that is all that is in any octane booster. The main point of using it is to get your "octane points" up. Especially in a turbo EVO.
Old Jan 15, 2004 | 08:04 AM
tswift's Avatar
here is the link to the article
http://evo.jedinite.com/toluene.html
Old Jan 15, 2004 | 08:32 PM
Snarlynx's Avatar
I read it and it sounds great. I've heard of it before but I've never seen it written out so well.
Shiv - Do you know anyone that uses this? I think it would be a good way to get around Cali's horrible gas if there are no side effects.
Old Jan 15, 2004 | 08:33 PM
BuLocal's Avatar
Thanks to all........i
Old Jan 15, 2004 | 09:09 PM
YellwTyper's Avatar
It just sounds too good to be true.... There has to be some real negative side to it all.
Old Jan 17, 2004 | 03:20 PM
BuLocal's Avatar
I belive the toluene would work great as a octane booster.....my only hesitation is that it might be kind of hard on any rubber part/hose in the fuel system (make it swell then get hard and crack). Not sure if the newer cars use a different kind of rubber...............
SMadi
Apr 18, 2015 09:40 PM
#1 cbr
Nov 8, 2011 02:43 AM
frankd14321
Jul 27, 2006 08:13 AM
emc51268
Canadian Forum
10
Apr 23, 2004 09:17 PM
janv
22
Dec 13, 2001 03:41 AM
