Progressive controller settings
Old Jan 5, 2006 | 06:10 PM
EvilBlueEvo8's Avatar
Have a SMC kit on the way. Was wondering what the start and max settings were. 10 psi sounds good to start spraying and 22 for full spray. is that good?
Old Jan 6, 2006 | 06:43 AM
anyone?
Old Jan 6, 2006 | 12:05 PM
fromWRXtoEVO's Avatar
Al tuned my car to start at 16PSI and ending 26PSI. I recently changed to 10psi starting and 26psi ending.Either way it works fine, just make sure you observed the settings very well before changing it so that if you ever go back to know where you suppose to set it.
Sorry if I was not to objective on the answer.
Old Jan 6, 2006 | 02:02 PM
no thats what i'm looking for. just seeing what everyones numbers are at. thanx
Old Jan 6, 2006 | 10:38 PM
bishiboy's Avatar
I would think you'd want the max to come in earlier. If you have a stock turbo. Pushing over 23-24psi gets it out of it's effcientcy and temps rise fast. I don't have a progressive controller...yet (coolingmist will be ordered soon). My on/off is set to kick in at 17psi. I think with a progressive unit, I'd start spraying around 10-12 and have it spraying max by 18.
If you've ever datalogged, you'll see that 16-18psi is where things start happeneing, (timing gets pulled and knock can happen).
This is all based on stock turbo.
Old Jan 7, 2006 | 04:43 AM
sweet. good points. i have a stock turbo. i'd like to get an 05 mr or a tme turbo in the future but it wont be till after the alky since the alky is on its way.
Jonno99
Mar 10, 2017 04:03 AM
boost556
Apr 12, 2012 05:29 AM
Ariofighter
May 10, 2004 05:49 PM
CarPhoto.net
57
Nov 25, 2003 02:51 PM
Boston'sEvO-->8
24
May 30, 2003 12:41 PM
