Nitromethane Q&A..
Old Feb 5, 2009 | 08:07 AM
  #166
berdugo's Avatar
any updates with this thread guys? I'm thinking of doing it too, planning to use 4 nozzles and 10& NM and 90% meth by volume.
for those who gained power and torque, what nozzle size did you used? thanks in advance guys
Old Feb 5, 2009 | 09:01 AM
  #167
esevo's Avatar
Be careful, running pure meth with nitro could be a explosive combo. I would run some water, to dilute it. Nitro can explode in the ic piping and make a mess. Especially with 4 injection points. I would start with 2 jets both 1.0mm 50% water 10% nitro and 40% meth.
This is a great but safer combo to start with.
Good Luck
Evan Smith
Old Feb 5, 2009 | 09:10 AM
  #168
berdugo's Avatar
Good Luck
Evan Smith
thanks a lot for the reply
btw anyone using a meth compatible lubricant like top oil from price chemicals or klotz uplon to lessen the abrasiveness of the meth and nm?
https://www.pricechemical.com/Top_Oil.html
http://www.klotzlube.com/storeProdDetails.asp?pi=20
thanks again
Old Apr 4, 2009 | 10:36 PM
  #169
EVOlutionary's Avatar
http://www.klotzlube.com/PDF/Tech/KL-600.pdf
http://www.klotzwarehouse.com/index.php?productID=8672
Has anyone tried Nitropropane additive?? It is about $65 per gallon, but it mixes with alcohol and gasoline. . . and you can find it at lots of ATV/MX shops. . .
I come from a quad-racing background and I know several folks who have used this with good effect. . .
They also sell Nitromethane, but it is pretty expensive after you figure in the shipping cost.
http://www.klotzwarehouse.com/index.php?productID=8640
SmurfZilla
Aug 16, 2015 03:50 PM
goforwand
Dec 29, 2013 07:47 PM
drifthobo
Dec 21, 2013 08:59 AM
