Perrin Meth Injection kit Primer Pump
I do not have the Flowjets for sale. For mine I searched online using the part number for the best price with reasonable shipping costs and purchased it, I think it was from a boat/marina supply company.
The barbed fittings for 6mm lines that you press into the pump inlet and outlet fittings I can help you with. If you get the pump send me an email with your shipping info and I'll get them out to you.
jackblalock(AT)gmail.com
Just to be sure though, make sure you have your basics covered since most of the time issues come down to a simple overlooked item or a small wiring mistake. You really do not need to do much more then review the quality your install and confirm that whats hooked up is in fact hooked up solidly. You would be surprised at how many times a lose wire, a bad ground or a feed line not fully tightened at the filter causes a problem.
there are several different flojets in that FL-122 series. Some flow
0-2.1 GPM
60 PSI (max)
$161
0-1.0 GPM
35 PSI (max) and 2 other pumps with the same flow and cost 80 and 70
$60
which one in ya'lls opinion would best suite my needs....I kinda need a fair amount of flow because of the turbo and boost I will be running.
Thanks for ya'lls help!!!
0-2.1 GPM
60 PSI (max)
$161
0-1.0 GPM
$60
Heres the one I used. Realize though, I never used a heavy methanol mix. I do not know how long this pump will last if your using 100% or otherwise a very heavy methanol mix. I still have mine and it was working the last time it was used and I had no issues with it so I think you will be safe with using it.http://www.pumpagents.com/FlojetPumps/LF122-202.html
Okay I would like to order those barbed fittings for 6mm lines that you press into the pump inlet and outlet fittings.
If I PM you my shipping information could you then PM me your prices???
I don't use my email very often so hotmail suspended my account.
Wanchai Panpron
Lancer Engine Tech
Nov 24, 2016 11:34 PM
Richard L
149
Feb 27, 2016 03:01 PM
EvoTio
34
Feb 19, 2006 09:08 AM
