Adding Ice to Meth Tank.
Old Oct 10, 2008 | 05:52 AM
  #61
dudical26's Avatar
hey thats a pretty cool product. You could put that between the pump and the meth tank. I wonder how much it can cool if there is constant flow.
In fact it might not even need to cool that quickly. If there is a decent amount of capacity for methanol, you might be able to hold a few seconds or a minuete or so worth of methanol, enough for one drag race for sure.
Old Oct 10, 2008 | 06:04 AM
  #62
evane's Avatar
plus with the line coiled around the inside a few times the meth will have to travel through the line in the cool can so it will cool down the whole time its circulating thru the line in the cooler can, plus the ice/ dry ice or ice/water will cool the line down also....should work pretty well IMO
Old Oct 10, 2008 | 06:44 AM
  #63
dudical26's Avatar
yea its should work for sure. Personally I have a lot of other stuff I want to try out so this will probably take a back seat for a while. Once I reach a point where 5% increase in cooling capacity is important, I'll give this a shot.
Old Nov 16, 2008 | 12:02 PM
  #64
Applesauce's Avatar
put some dry ice or liquid nitro(196 degrees Celsius) in a can, take some copper tube put it inside the tank, make the tube long enough to reach ur meth tank, and wrap it around the meth tank. simple diy.
whitevo88
Nov 17, 2011 08:00 AM
pcamara17
53
Jun 14, 2010 08:46 AM
1mbrews8
Nov 17, 2007 02:54 PM
eve-slow
May 29, 2007 06:22 AM
DS-03evo
32
Feb 17, 2007 09:09 PM
