100% Water, anyone making power?
I'm looking into the Aquamist HFS-5 and the biggest reason I haven't bought it yet is the whole idea of having to constantly refill your meth. I searched all last night during my graveyard shift and came up with nothing. Does anyone have any hard numbers using a water/meth kit using 75-100% water? And if so are you making good power? I'm not worried about the price of the kit. It's the inconvience of looking for and supplying my meth.
One downside he ran was that the water injected was causing missfire(too much water), HKS DLI II fixed the issue.
Carlos
Abner (slowcar) made good power numbers and torque a few years ago on his stock turbo Evo 8 9.8 hotside. His power was great and he even achieved his goals with 87oct. It has been done, I would definately consult with him.
Carlos
Carlos
Okay grenade maybe you can help get some rough numbers. If you use a 2.5 gallon container, how much meth(%) are you gonna use? How often would you fill it? Then I can gage how much it costs per gallon and figure out what I'll be shelling out a week to fill my meth. I'm not an aggressive driver by any means. I drive 80miles roundtrip from work and I would like the meth kit to be Active but not eat up my meth supply while I'm cruising at 70mph on the highway.
the aquamist , and I suppose the other kits too, only spray when you are boosting more than about 10 psi. Your Meth will last forever if you don't boost more than 10 psi.
The most important thing I have found is to use distilled water so you don't get the mineral build up. Using washer fluid would be a big no for me as it will clog the jet over time.
I have been running straight water but have some meth waiting for me. I'll run 50/50.
remember...100% gives cooling and increases octane like race gas. Water reduces temps more, will not yield same results as 100%meth. I would use water as adder for better temps with a big turbo/race setup. Don't waste your time with water...
I should have expected the reponses I'm getting. Thanks guys. I didn't know you could control off of just boost settings, I thought it was a lot more complicated than that. I'll need to find a reliable source of methanol still.
Heres a link that has the MSDS on Superclean windshield washer fluid. Same for SuperTech
http://www.superclean.com/pdf/Splash_Wash_4.pdf
You're not gonna waste meth while cruising...only when you hit the boost you set your kit at, idc....I purchase a sealed VP 5 gal drum roughly every 1-2 months.
Check www.vpracingfuels.com or call your region for a list of local distributors.
VP-Atlantic
Newark, DE
Phone: 302-368-1500
Fax: 302-368-1869
vpatlantic@vpracingfuels.com
VP-Atlantic
Newark, DE
Phone: 302-368-1500
Fax: 302-368-1869
This came off a corvette forum. The guy was an evo owner.
Not a vette, but my Evo is making and tuned for 500awhp on pump gas with Windshield Wiper Fluid. The lower the rating of the Wiper Fluid the more effective it is. I used the -20F.
Thanks Evoryder....now that's some good info. If I can do half of what you're doing and mix 50/50 then maybe I'll only have to buy it every 2-4 months theoretically.
First I'm trying to gage how much i'd use seeing as though it's a daily driver and I only accelerate somewhat hard when I'm going onto the highway ramp. Other than that it's normal driving. If what you're saying is correct and I'm sure it is then I won't use as much as I thought I was. So meth wouldn't be as much of a pain as I though.
Using washerfluid is like drinking water from a hose. Sure it's water, but wouldn't you rather either filtered water or something from a bottle?
You should buy in bulk. That way it lasts longer, and will not have you going back and forth every few weeks.
