Can meth burn up the idle control sensor?
Old Jun 24, 2008 | 07:01 PM
Inprogress's Avatar
So the Aquamist kits shouldn't have the extra meth dribble that kills the IACV's?
Old Jun 25, 2008 | 12:24 AM
Richard L's Avatar
Can someone take a picture of the IACV for me?
If the valve is made of aluminium, the meths may cause corrosion within theair path. If this is the case, spray a samll amount of WD40 may coat the internals and minumise the corrosion process.
I assume the valve is running everytime the car idles?
Old Jun 25, 2008 | 12:33 AM
Richard L's Avatar
The difference bewteen the aquamist system is "inline valve (quick shut off)" vs "checkvalve (slow shut off)" of the PPS systems.
If "meth to IACV" ingression is caused by main injection event. there is no difference which system you use.
I believe having a continue-on spray after the shut off period does not help the matter, this is because the IACV is most active during idle or zero throttle.
Old Jun 25, 2008 | 01:15 AM
Inprogress's Avatar
I don't believe it's aluminum, because people aren't talking about metal corroding, i've heard it melts them, not exactly sure what melts though.
Old Jun 25, 2008 | 01:47 AM
Richard L's Avatar
Can I assume it is made with some form of plastics?
Old Jun 25, 2008 | 02:08 AM
wartownracer's Avatar
what is the iacv? sorry for the newb question. I have a met kit waiting on me to get installed when i get back from iraq...im just trying to grasp the tech side of it all.
Old Jun 25, 2008 | 02:11 AM
Inprogress's Avatar
https://www.evolutionm.net/forums/sh...0&postcount=19
There's the link to the post buschur made himself regarding some of the model stepper motors on Evo's having a plastic tip and those were melting. People with older model Evo's should have a steel tip thus they're not having any problems.
Old Jun 25, 2008 | 02:59 AM
4drboost's Avatar
What are the symptoms of a bad IACV? I'm having miss fire at idle, could this be the symptoms? TIA
Old Jun 26, 2008 | 08:24 AM
Boltz.'s Avatar
FCOTM Winner
Wavy, Surging idle. A misfire is most likely another problem
Old Jun 26, 2008 | 04:33 PM
nikkadanny's Avatar
i just unpluged the iacv and adjusted the idle and it starts up fine and runs like normal
Old Jun 26, 2008 | 05:01 PM
Inprogress's Avatar
What was adjusted in your idle?
Old Jun 26, 2008 | 05:10 PM
Mitsutech56's Avatar
The steel ones are more robust but still have the problem with the meth weeping into the electrical portion and melting the coating on the windings. The windings then short together and the CEL comes on and the IACV doesn't move. The shorted windings cause excess current draw on the transistor in the ECU. This was the major cause of ECM failure on the old DSMs.
Old Jun 28, 2008 | 12:42 PM
Richard L's Avatar
- what is inside the tip?
- What is the function of the the winding?
- anyone got a drawing of the internal circuit?
Please help, any one.
BrownSuga
May 20, 2016 01:36 PM
loyal0ne
Feb 7, 2011 07:48 AM
turizmo01
Aug 8, 2010 01:13 PM
mrdevo
19
Feb 25, 2009 09:22 PM
cpoevo
20
Oct 5, 2007 12:10 PM
