Project X - Water/Meth Install!
Old Feb 21, 2010 | 10:11 PM
  #106
tephra's Avatar
How good is Richard/Aquamist... He is going to send me a longer ECU/Yellow harness
awesomeness!
Old Feb 25, 2010 | 03:08 AM
  #107
tephra's Avatar
ok back onto the topic of jet choice.
is it ok to have a 0.5mm and 0.8mm together? any reason not too?
Old Feb 27, 2010 | 10:27 PM
  #108
tephra's Avatar
well it's all in
system tested out well - so now I just have to get some meth AND tune it
the only real problem I had was over-tightening the jets.
I snapped the 0.5mm jet in half, and I snapped howertons lovely 90deg angle thingy as well
so Now I only have a 1.0mm jet installed because I think a .8 and .9 would have been too big..
I might get some more jets in the near future and I will reinstall them.
tapping the LICP was pretty easy, you need to hold the tapbit very very straight/steady whilst it's going in...
so this week I will pick up some meth + more distilled water then I will begin tuning it all
Old Feb 28, 2010 | 04:43 AM
  #109
Richard L's Avatar
Great news!
Is the Evo X tunable by an individual with the domething likr the ECU flash etc? I am not up to date on them.
Old Feb 28, 2010 | 05:22 AM
  #110
tephra's Avatar
yes...
fuel/timing/boost/mivec/everything basically...
hope to altmaps up soon...
Old Feb 28, 2010 | 08:08 AM
  #111
mt057's Avatar
Originally Posted by tephra
well it's all in
What boost are you going to run? Stock turbo? Sorry if I missed it.
Old Feb 28, 2010 | 02:09 PM
  #112
tephra's Avatar
yeah stock turbo.
the maxit will run upto redline...
probably 28 or so at pk tq
Old Mar 2, 2010 | 02:55 AM
  #113
tephra's Avatar
ok so its all working pretty well.
i had some teething problems with air bubbles... (basically after I finished testing with 100% water, I drained and refilled with 50/50 - that introduced some bubbles which was causing havoc with the FCM)
seems to be good now.
ok so how do I know what injection % I should be running? the manual says 15-20% for 50/50, what are peoples experiences?
Old Mar 2, 2010 | 02:00 PM
  #114
scheides's Avatar
EvoM Moderator
Awesome tephra!
I think I'm running over 20%, a single 1mm jet was fine but I wanted more, so I upped it to a 1mm + a .9mm further down the intake tract. That's at the high-end of what you'd need to run. On a stock turbo, I think a single 1mm jet is perfect, or maybe 2x .6mm jets if you really want to space them out a bit for a combined octane suppression/air cooling effect.
Enjoying the torque?
Old Mar 2, 2010 | 02:06 PM
  #115
tephra's Avatar
yeah im thinking of going 2x0.6 or 2x0.7.. everything is setup for twin jets.
i havn't changed the tune yet, need to get map switching going first...
Old Mar 2, 2010 | 04:48 PM
  #116
tephra's Avatar
ok I did a pull using the same tune as before, but now with meth.
I actually lost power... about 10 hp...
I put this down to being richer (11.7 -> 11.0) and I lost a little boost as well...
Old Mar 6, 2010 | 09:41 PM
  #117
Hiboost's Avatar
Lean her back out and raise the boost, it will make power!
Old Mar 6, 2010 | 09:55 PM
  #118
scheides's Avatar
EvoM Moderator
Yea, gotta add timing and lean it out. Excited for mapswitching!
Old Mar 7, 2010 | 01:07 AM
  #119
tephra's Avatar
yup I will
map switching is working..
this week is toon week
Old Mar 7, 2010 | 04:23 AM
  #120
Richard L's Avatar
Fantastic news!
