Post up how much meth you spray
Old Mar 26, 2011 | 07:11 AM
mt057's Avatar
I would like to see how much methanol people are spraying with their given setups. Post up... What system you are using, what size jets/nozzles, and percentage of meth to water. If you want to add more feel free.
To get it started, I currently run a hta35r at about 28/29psi. Motor is stock beside S1 cams. I am running an Aquamist HFS-3 with two 1mm jets using 100% meth. I am considering installing a third jet soon. Any thoughts?
Old Mar 26, 2011 | 01:20 PM
raasfaas's Avatar
I'm running a Red @ 26psi on a stock block w/mods in my sig...I'm on an AEM kit currently using the 2-med jets (approx. 630ml/min) @ 60/40. I'm thinking of spraying a bit more and go with the big+med jets (approx. 865 ml/min)
I wouldn't mind adding another jet to the mix but I'm running out of room on my uicp post bov.
Old Mar 27, 2011 | 08:28 PM
Go_Lancer_Go's Avatar
hows your car enjoying 100%? i heard thats hardcore
Old Mar 27, 2011 | 08:40 PM
mt057's Avatar
^Its been hooked for years. Just doesn't act right with out it
Old Mar 27, 2011 | 08:41 PM
xBLK21LEVO9x's Avatar
How are you running multiple nozzles?
Old Mar 27, 2011 | 09:41 PM
mt057's Avatar
I use a compression T fitting I got from Howerton Engineering. Here is a pic....
I thinking about upgrading to a multiport bar that will allow me hook up 3 nozzles off the same line. Another thing I am thinking about doing is switching out to -an lines.
Old Mar 29, 2011 | 03:21 PM
C6C6CH3vo's Avatar
Two pumps (labonte)
5 or 6 nozzles (labonte) I can't remember if the 6th is currently hooked up
2 ea controllers (Hobbs motorsports)
I spray enough 90+% methanol to allow stock injector duty cycle < 97% at 30+ psi on bbk full
Old Mar 29, 2011 | 06:41 PM
mt057's Avatar
Originally Posted by C6C6CH3vo
Two pumps (labonte)
Wow, 5 or 6 nozzles I guess that a third wouldn't hurt
Where all do you have them? Any pics?
Old Apr 19, 2011 | 08:50 AM
dubbleugly01's Avatar
Built motor with a GT35R snail. I'm running 4 direct port jets (.4mm) and a single nozzle in the charge piping (.8mm) after the intercooler. Running about 85% meth at the moment. This is with the Aquamist kit.
Old Apr 21, 2011 | 07:08 AM
EvoPower81's Avatar
Hate to highjack your post but wanna know what afrs are you guys running with the 100% meth with these multiple jets
Old Apr 22, 2011 | 09:14 PM
C6C6CH3vo's Avatar
Methanol will burn fastest at all temperatures at a 1.2 equivalence ratio. Grabbing my calculator 1/lambda = 1.2, so lambda .83 will be the majic AFR. Thats low 12's afr, pretty dam close to gasoline.
BTW, methanol/ gasoline mix will burn much faster than ethanol if anhydrous and a good amount. Dirty little secret
Old Apr 24, 2011 | 11:28 AM
EvoPower81's Avatar
. Ill try 12.0 and see how it likes it. Im getting some spark blowout in 1st gear when im on the rev limit too long. No problems with 3rd at all. I guess the stock ecu doesnt compensate for the lower gear loads hence richer afrs in 1st and 2nd
evoxsi
15
Sep 15, 2012 06:11 AM
EvoPower81
10
May 11, 2011 07:03 PM
hawaiian_evo
Mar 14, 2009 08:22 PM
saiyanzzrage
Automotosports - Illinois
33
Nov 15, 2006 09:39 AM
