Quick questions and please double check my math.....
Old May 3, 2011 | 08:30 PM
DaGermanEvo9's Avatar
Hey guys and girls, I'm getting ready to install my Aquamist HSF-6. I just want to run by everyone how I plan on running it. I also want to run the math by everyone. Ok here we go!!! By the way I'm using the information from the manual and from Howerton Engineering.
I'm running 950cc injectors, 50/50 Mix of Water and Meth, and 26psi Peak boost
950 X 4 = 3800
50/50 calls for 20% of fuel flow
3800 X 0.2 = 760
add 10% system losses:
760 X 1.1 = 836cc
The new pump runs 165psi, subtracting 26psi Peak Boost gives you 139psi ( I rounded up to 140 ). Can I do it that way or does it have to be exact?
So with that amount of required injection I'll need to run a dual nozzle set up. Looking at the chart provided I'll need to use a 1mm ( 548cc ) and 0.5 ( 284cc ) for a grand total of........ 832cc total injection.
Not quite 836, so here is a question for everyone. Should I run as close to the required cc or should I run over that amount and limit it down some how?? Also I want to run the nozzles with the 1mm about 16-18inches from the TB and the 0.5mm at 12 inches or so. Ok I think thats all I got let me know what you think, and hopefully this all makes sense im not entirely sure it even makes sense to me!
Old May 4, 2011 | 08:41 AM
Bump, anyone one???
Old May 4, 2011 | 07:21 PM
come on......
Old Sep 5, 2011 | 08:56 AM
Boltz.'s Avatar
FCOTM Winner
950 X 4 = 3800
3800 X 0.2 = 760
760 X 1.1 = 836cc
Just a quick reply but you have to take into account your actual injector duty cycle. You can't just assume you're using the entire injector as your math states. Also, if you use your current IDC into your equation it will also be false since with the meth and water you will not only have additional fuel, but because of the water you'll also have a leaner targer AFR.
Old Dec 11, 2011 | 08:13 AM
Vigman's Avatar
Start with 1 + 0.5 looks good to start with something.
Spending time logging and tuning is the best solution to get everything working properly.
esevo
43
May 31, 2015 05:55 AM
Biggy VIII
10
Nov 19, 2010 12:56 PM
kirkklau
Oct 20, 2009 01:26 PM
ecuflasher
Jul 12, 2008 02:55 AM
hellcat
Jan 29, 2008 02:48 PM
