Las Vegas Evo's
Old Jan 6, 2008 | 10:20 PM
  #42781
20psiMR's Avatar
NLTS didnt work too well for me, it was kicking on during hard acceleration without being wide open throttle. Would hit a corner hard and go WOT, and it would pause about 2 seconds before allowing the throttle to go 100%. Was really weird. Can probably play with settings but since I dont drag anymore I wasnt worried about it.
The knock light Ive been running full time for about the last 6 months. Map switching is on the very near future too
Old Jan 6, 2008 | 10:27 PM
  #42782
wesside's Avatar
I've turned of NLTS but hey what do you think about the idle issue with the 720cc's? Since I've already changed the injector scaling & latency voltage.... Fuel trims?
Old Jan 7, 2008 | 01:06 AM
  #42783
gonzo's Avatar
Originally Posted by steexz
^^ ftw :-)
Diesel or DIAF!
Old Jan 7, 2008 | 01:54 AM
  #42784
bchappy's Avatar
Originally Posted by wesside
Nice bro & I hope you killed it in beer pong..I did
I got those injectors installed just trying to get my idle right. I've changed the injector scaling and latency so umm maybe if someone wants to help me out alittle I've got maps and lots of logs
O hey I've done this
https://www.evolutionm.net/forums/sh...highlight=nlts
And I've got to say the valet mode is funny and I like the knock cel light
trust me manny was killing alot of **** last night..
we got to start whoring out his roommate to sing in american idol steve has got teh skillz
Old Jan 7, 2008 | 05:43 AM
  #42785
wesside's Avatar
Haha scuba steve was singing?
Old Jan 7, 2008 | 09:31 AM
  #42786
SiCKlEyWiKeD's Avatar
no it was my roommate steve. Best f'kn white mormon rapper you'll ever hear....
btw: wes you do have cams?
Old Jan 7, 2008 | 09:41 AM
  #42787
wesside's Avatar
You should've got that on video
Yep hks 272's
Old Jan 7, 2008 | 01:11 PM
  #42788
Yep hks 272's
I thought you've seen him before? You haven't lived till you seen him sing "stuntin like my daddy"
Old Jan 7, 2008 | 02:10 PM
  #42789
20psiMR's Avatar
Check the fuel trims...if using evoscan, they should all be at 100. If they are not, then your settings could be wrong. Basically with 720's your scaling should be - 10% so around 648 (I think thats the calc, I cant member exactly) and this is what I have for RC720's
2.186 1.518 1.032 0.694 0.443 0.268
If your fuel trims are off, you can make small adjustments to the scaling and that could do it. The voltages are fine tuning from there.
Old Jan 7, 2008 | 02:22 PM
  #42790
wesside's Avatar
yea the trims are not at 100 and evoscan flips them right? so the high well I should say low is in the 80's so I think I'm getting closer I'm going to test out what you use for 720's and see
EDIT:
So All the fuel trims are at a 100 now
scaling at 650
3.912
3.192
2.592
1.32
0.888
0.672
0.408
now I will go log the car on the road some more and see where I'm at and see how its running
Old Jan 7, 2008 | 02:52 PM
  #42791
20psiMR's Avatar
I havent used it before, I actually havent had to any injectors yet. I have a spreadsheet that someone put out with the voltages for most injectors, so thats what Im going off of for those. If you put in those voltages/scaling and its still off, just adjust the scaling up or down to get the trims close. You want them to be within 5% of each other.
Old Jan 7, 2008 | 03:25 PM
  #42792
wesside's Avatar
K thanks chris I'm noobish to begin with and never had to touch the injector stuff but its good stuff for me to learn since I've got vegas 2hrs away and salt lake 4hrs for tuning =[
Old Jan 7, 2008 | 05:48 PM
  #42793
brian250f's Avatar
damn, according to fedex they dropped off my CF exhaust shield on saturday, but there wasnt anything by my door. got home too late to check if the front office got it. i really hope thats it and some kid didnt pick it up b/c he will have no use for it has this happened to anyone? file a claim with fedex? hopefully that wasnt just money down the drain...
Old Jan 7, 2008 | 09:51 PM
  #42794
20psiMR's Avatar
No worries man, you know Im always down to lend a helping hand.
Old Jan 8, 2008 | 08:05 AM
  #42795
wesside's Avatar
woot just about got it, just need to get the cruise at 100% when I really do get it I'll let you know what settings I used. I might have to raise the idle up a bit to help the dying down and possibly raise the timing up a bit in the idle cells depending on what it is at.
