Utah Evos
Old Sep 15, 2008 | 09:05 AM
  #17941
33's Avatar
33
You guys should have seen the chick that I met down in the Gateway! Hot little petite blonde riding a GSXR...and she is part of a chicks bike club. Hopefully I will get to party with her this weekend
Old Sep 15, 2008 | 09:23 AM
  #17942
wesside's Avatar
Jake I desperately need to get my brake dust clean and get off those evo vs lambo bugs on my front end omg its so bad haha maybe when I throw on those stoptech slotted rotors I got I'll clean the inside of the wheels really good too might as well
evo > bugs
**** there caked on probably going to be a pain to get the car clean now
Nelson hot chicks FTW
Old Sep 15, 2008 | 09:38 AM
  #17943
Jorda420's Avatar
Originally Posted by rEVoLed
didn't you use to work at Jiffy Lube on 90th and redwood rd? I've seen a evo with a lancer spoiler parked there. I thought it look very sleeperish.
Yep that's me. But I now work at Just emissions 100 yards west of J-lube. The wing throws every body off
Old Sep 15, 2008 | 09:44 AM
  #17944
Jorda420's Avatar
Originally Posted by UT_Evo
Jordan, you ****in know me, why didn't you wave?
I dident realize it was you. Your car looked super clean
Old Sep 15, 2008 | 10:33 AM
  #17945
33's Avatar
33
Hot chicks in St. G. FTW
Old Sep 15, 2008 | 10:46 AM
  #17946
wesside's Avatar
your right but I'm sick of em
Dallin btw I'm not sure if you wanna go to e-85 in the winter from what I know it's not a good cold fuel. Here's some info that I posted for the vegas evo guys
Water contamination
In addition to corrosion, there is also a risk of increased engine wear for non-FFV engines that are not specifically designed for operation on high levels (i.e., for greater than 10%) of ethanol. The risk primarily comes in the rare event that the E85 fuel ever becomes contaminated with water. For water levels below approximately 0.5% to 1.0% contained in the ethanol, no phase separation of gasoline and ethanol occurs. For contamination with 1% or more water in the ethanol, phase separation occurs, and the ethanol-water mixture will separate from the gasoline. This can be observed by pouring a mixture of suspected water-contaminated E85 fuel in a clear glass tube, waiting roughly 30 minutes, and then inspecting the sample. If there is water contamination of above 1% water in the ethanol, a clear separation of ethanol-water from gasoline will be clearly visible, with the colored gasoline floating above the clear ethanol-water mixture.
For ethanol contaminated with larger amounts of water (i.e., approximately 11% water, 89% ethanol, equivalent to 178 proof ethanol), considerable engine wear will occur, especially during times while the engine is heating up to normal operating temperatures. For example, just after starting the engine, low temperature partial combustion of the water-contaminated ethanol mixture takes place and causes engine wear. This wear, caused by water-contaminated E85, is the result of the combustion process of ethanol, water, and gasoline producing considerable amounts of formic acid (HCOOH, also known as methanoic acid and sometimes written as CH2O2). In addition to the production of formic acid occurring for water-contaminated E85, smaller amounts of acetaldehyde (CH3CHO) and acetic acid (C2H4O2) are also formed for water-contaminated ethanol combustion. Of these partial combustion products, formic acid is responsible for the majority of the rapid increase in engine wear.
Engines specifically designed for FFVs employ soft nitride coatings on their internal metal parts to provide resistance to formic acid wear in the event of water contamination of E85 fuel. Also, the use of lubricant oil (motor oil) containing an acid neutralizer is necessary to prevent the damage of oil-lubricated engine parts in the event of water contamination of fuel. Such lubricant oil was required by at least one manufacturer of FFVs (Chrysler). This requirement was later removed.
For non-FFVs burning E85 in greater than 23.5% E85 mixtures (20% ethanol), the remedy for accidentally getting a tank of water-contaminated E85 (or gasoline) while preventing excessive engine wear is to change the motor oil as soon as possible after either burning the fuel and replacing it with non-contaminated fuel, or after immediately draining and replacing the water-contaminated fuel. The risk of burning slightly water-contaminated fuel with low percentages of water (less than 1%) on a long commute is minimal; after all, it is the low temperature combustion of water contaminated ethanol and gasoline that causes the bulk of the formic acid to form; burning a slightly-contaminated mix of water (less than 1%) and ethanol quickly, in one long commute, will not likely cause any appreciable engine wear past the first 15 miles of driving, especially once the engine warms up and high temperature combustion occurs exclusively.
For those making their own E85, the risk of introducing water unintentionally into their homemade fuel is relatively high unless adequate safety precautions and quality control procedures are taken. Ethanol and water form an azeotrope such that it is impossible to distill ethanol to higher than 95.6% ethanol purity by weight (roughly 190 proof); regardless of how many times distillation is repeated. Unfortunately, this proof ethanol contains too much water to prevent separation of a mixture of such proof ethanol with gasoline, or to prevent the formation of formic acid during low temperature combustion. Therefore, when making E85, it becomes necessary to remove this residual water. It is possible to break the ethanol and water azeotrope through adding benzene or another hydrocarbon prior to a final rectifying distillation. This takes another distillation (energy consuming) step. However, it is possible to remove the residual water more easily, using 3 angstrom (3A) synthetic zeolite pellets to absorb the water from the mix of ethanol and water, prior to mixing the now anhydrous ethanol with gasoline in an 85% to 15% by volume mixture to make E85. This absorption process is also known as a molecular sieve. The benefit of using synthetic zeolite pellets is that they are essentially comparable to using a catalyst, in being reusable and in not being consumed in the process, and the pellets require only re-heating (perhaps on a backyard grill, in a solar reflector furnace, or with heated carbon dioxide gas collected and saved from the fermentation process) to drive off the water molecules absorbed into the zeolite. Research has also been done at Purdue University on using corn grits as a desiccant. [3] Once the ground corn becomes water logged, the corn grits can be processed much as the zeolite pellets, at least for a number of drying cycles before the grits lose their effectiveness. Once this occurs, it is possible to run the now water-logged corn grits through the natural fermentation process and convert them into even more ethanol fuel.
It's a good read..."Ethanol is NOT a cold weather fuel."
http://www.fuelsrc.com/index.php/200...h-and-testing/
Old Sep 15, 2008 | 10:58 AM
  #17947
Fairclough's Avatar
So I washed my car (since the bikini thing was a bust... and since Wes and I woulda missed it anyway)...
I used some wheel cleaner stuff that is totally freaking awesome, here's some pics and my mini-review
https://www.evolutionm.net/forums/sh...d.php?t=369467
And here's the clean Porsche
And the view most of you usually see
I've never seen that end before Jake, you must be talking about the other Evo guy's.
Old Sep 15, 2008 | 11:00 AM
  #17948
Fairclough's Avatar
Sounds good I'll give you a call after that or before if I can
I don't fly out until 1:35pm so i'll be on here until then.
Old Sep 15, 2008 | 11:11 AM
  #17949
wesside's Avatar
Jake don't even chim in and say me I had to follow him when we were out getting some food &
Old Sep 15, 2008 | 11:33 AM
  #17950
Jorda420's Avatar
Way off topic....I'm parting out my 1968 GMC low-rider. Does anybody need airbags or pumps. I also have a Early Classic front disc brake conversion for 67-72 chevy and a th400 trans.
Old Sep 15, 2008 | 11:50 AM
  #17951
UT_Evo's Avatar
Thanks Jordan, it wasn't clean then I was meeting Wes for hangover breakfast.
And Jason, don't lie, you see the rear end all the time Hahaha.
Old Sep 15, 2008 | 12:48 PM
  #17952
33's Avatar
33
Is the truck still whole? You have any pics of it? Thats my favorite body style for GM trucks (although I like chevy more)
Old Sep 15, 2008 | 01:18 PM
  #17953
33's Avatar
33
OMG got some fresh new meat that just came in from Oregon to stay with her sister for a couple months. Cant wait to take her out! Just came to get a pass to get on base. All I can say is
I love being single!
Old Sep 15, 2008 | 01:32 PM
  #17954
UT_Evo's Avatar
Keep telling yourself that
Old Sep 15, 2008 | 02:39 PM
  #17955
Jorda420's Avatar
Is the truck still whole? You have any pics of it? That's my favorite body style for GM trucks (although I like Chevy more)
Its still whole but its a 3 door suburban (sorry my bad) but its the same kit as the trucks use. Its yours for $2500 I'm in to it 6k . Kindigit design did the drop and bag work. I'm striping bags etc. then its going to the crusher on Friday.
