How Much Horsepower do i get out of an ECU Flash???
Re: Re: Re: Re: Re: Re: How Much Horsepower do i get out of an ECU Flash???
Originally posted by DSMBRETT
[all about the Xede]
While this Xede sales talk on the WORKS forum is unwarranted from both Shiv/Brett and heshamnaim (whoever that is), I will concede one point to Shiv -- the Brain flash and Xede are geared towards two different types of Evo owners. The Xede lends itself towards those that anticipate tinkering with their settings, while the Brain flash is, as I described it above, a "plug and play" solution.
That said, let's leave the Xede sales to Shiv's forum (located at his website) and I'm sure he, Brett, and heshamnaim will do their best to educate and inform there as to that product's virtues.
-- DavidV
Re: Re: Re: Re: Re: Re: Re: How Much Horsepower do i get out of an ECU Flash???
Originally posted by DavidV@WORKS
Did someone leave out the welcome mat?
-- DavidV
-- DavidV
Originally posted by Daveyd
Dave,
Can you please answer that question....
Dave,
-- DavidV
So, are you saying that one should not install a Boost Controller AFTER receiving your reflash and running it at 19psi to redline? If one does, is there any risk of any type of damage
Originally posted by broeli
It would be nice to see a 19-20psi to redline integrated into the reflash though or one that is tuned to work with an mbc holding boost at 19-20
Yes, we can. Will we? Nope. Does that mean we aren't evaluating increased boost applications? Nope. Is there an intake in the "WORKS"? Maybe. Will it come with its own reflash if there is one? Most definitely.
I mean people can increase their bost for FREE on the evo to 18PSI to the red, just like in the 2G TSI AWD, just remove the Waste Gate Solinod restrictor, which is just a brass restictor in the line running from the watgate. You remove this, you get faster spoolup up, and another 2PSI up top BUT still follows the fastory slight falloff of 20PSI spike settled to 18PSI.
Again, I wish to buy your ECU, but if you can make this ECU with a 93 flash set for higher boost, for the love of God please make one for us, I just don't get that you are evaluating but won't step foward, very ambigious in your statments.
Could this be offered? I figure a slight increase in fuel coupled with maybe s slight retard in timing to allow more boost and more HP accorss the board. But you tell me, seriously, I want to boost and so do a lot of people,. this 16PSI ain't gona cut it for long as every other piggy back/flash/ECU runs atleast a MBC upped. Oh and I realize that just adding boost won't make power, but you have the opportunity to increase boost AND tune the car perfectly, every RPM incriment, the whole timing curve, so why not offer a flash that allows a boost increase? If you can make on for an exhaust (Obviously higher boost/ more air flowing through the turbo/engine/ more power needs more fuel, can't you do the same quite easilly?
So, are you saying that one should not install a Boost Controller AFTER receiving your reflash and running it at 19psi to redline? If one does, is there any risk of any type of damage?
Dave, Can you comment on this please..
That said, we are presently wrapping up some long-term boost evaluations that we have had underway for some time, so it might be worth it to wait for our official response when that evaluation is complete.
-- DavidV
S2K2EVO
Nov 2, 2011 12:52 PM
marinejensen
Aug 22, 2011 08:44 PM
MI_Evo8
13
Jan 29, 2004 02:09 AM
Any roundabout time until you have a boost integrated ECU reflash? Sometime in the beginning to mid of August maybe??
