88770005 xml needed !!!! please help
Right, I've downloaded ECUFlash 1.44.3719, done a bit of mucking around with rommetadata locations (only because I've mucked around with them previously for some weird issues I was having a while ago). And now I get the following tables:
Much much better, it's quite relieving to finally have a a good definition opening properly after looking for so long. Thanks for the help Todd.
that s the job
mivec table cannot change
Hi:
I using evo 9 wagon 6 speed i try the definitation but it cannot edit the mivec map, what file should i use at rommetadata
can any one pls help
request xml file
Hi:
Can anyone email me the 88770005 XML file to cxabrunei@gmail.com
Because i want to edit the mivec timing and fuel timing and boost timing
Thank you
Thank you
Gentleman. Here are the relevant XMLs. Ensure that the version of ECUFlash you are using is 1.44.3719 to display all the tables correctly (I have not used the latest versions so I do not know if they work well but I know this one does work).
