Walbro 450 lph e85 fuel pump diy evo 8/9
#242
I used Polyethylene. Specifically TEMCo 3/8" Diameter HD 3:1 Glue Lined as they claim it to be fuel and oil resistant. They also make fuel storage drums out of polyethylene.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
-pal215
-pal215
#246
Did yours let u drive it when it turn on?
Hey i install mine did everything pretty good...it turns on but it turns off in couple of mins...doesnt move eithet let clutch go while its on but doesnt move:0...any one had this problem? Or will i need a new Base Map:0 lmk plz
#251
Anyone regret going with the 450?
I'm gonna install mines this weekend. I hope it's worth it. I hope all goes well.
#252
Got it done!
So everything went well. My fuel pump didn't go all the way in bec the black rubber part is still visible even though I trimmed the housing and added my o rings. I'm still on my previous tune but I added a bigger turbo and the walbro 450. Car idles good, did one pull in 3rd gear and afr's were at 13-15@ wot. But the car feels great and the turbo feels great. Afr's were in the 10s before I added the walbro. Hoping to be tuned soon. I'll update if I'm leaning out bec of the black rubber piece not being in all the way.
#253
After doing this my car only cranks and will not start...💔 I turn on to on position and crank it for half a second and can hear the pump prime. I sprayed carb cleaner and it turned on for one second... my fuel rail is dry aswell any ideas?????
Tommyfacekicker (Apr 6, 2017)
#255
I get fuel in the rail not passed injectors now. I've tested injectors separately and they all work fine also tested fuel pump and all relays everything except ecu. My tuner said it can prob be ecu since that's what controls injectors? Any ideas?
