question on brakes
Old Feb 16, 2017, 05:23 PM
Bhsj13's Avatar
question on brakes
So, about 1k miles ago i had my brakes and rotors replaced with the new stoptech street pads (they had shims already on the back side) so i did not reuse old shims and centric blanks all around. they squeal so loud (like a train) but only with mild to low braking and at slow speeds. it stops on a dime with hard braking. bedded them a few times already. its driving me nuts! i didnt use any stop squeak goop or replace the caliper pins and springs. any suggestions? thanks guys!
Old Feb 16, 2017, 05:37 PM
Evo VI.'s Avatar
The squealing will sometimes disappear after pads reach a certain point.
Have had that before with harder pads that give off less dust.
Some pads just don't suit the disc.
Old Feb 16, 2017, 06:50 PM
Received 1,384 Likes on 1,317 Posts
Recommend putting the OEM angled shims back-in front & rear. That stopped my issue years ago when my brakes were howling
They're angled for a reason
Old Feb 17, 2017, 06:04 AM
CaptainSquirts's Avatar
^^^ Do what he says ^^^
I installed ferodo ds2500's on my car and holy crap they squealed hard. I Put on Girodisc quiet shims and some disc brake quiet (like copper anti seize but better?) and same outcome. I had to take pads off and reinstall the angled shims that come with the car and that stopped it.
Old Feb 17, 2017, 05:35 PM
Bhsj13's Avatar
ill try that guys and report back with results. thanks a lot! you guys think i have enough clearance to add the shims?
btw, these are the ones i have.
http://www.stoptech.com/images/defau...l.jpg?sfvrsn=0
Old Feb 17, 2017, 05:45 PM
I run the same brakes. Just run the OEM shims. Certainly no need to stack the ST shims w/the OEM's
Old Mar 9, 2017, 12:54 PM
Bhsj13's Avatar
okay, i know a month later now. I got the OEM shims for front and rear today. they will go in this weekend. i will report back afterwards. should i lube the other metal to metal surfaces? what lube? thanks guys for the help!
Old Mar 9, 2017, 05:21 PM
Michael Clennan's Avatar
I have a brand new Evo FE, broken in 5k miles on it. My brakes squeak when I come to stops at a slow speed. Any suggestions on a brand new car?
Old Mar 9, 2017, 11:12 PM
ziegler1224's Avatar
almost all performance pads will sqeak when they are not hot. very annoying
Old Mar 9, 2017, 11:41 PM
FullBlown8's Avatar
ceramic pads for ya
Old Apr 4, 2017, 08:20 PM
any suggestion on new performance pads that wont squeak? A nice car that squeaks is a little embarrassing.
Old Apr 4, 2017, 09:37 PM
barneyb's Avatar
If all we are talking a little squeak first thing in the morning or at low speed I'd say run what you have. Good brakes are hard to keep quiet.
Old Apr 5, 2017, 02:46 PM
Bhsj13's Avatar
yeah i havent gotten around to doing the shims. the squeak really doesnt bother me that much anymore. they do have great stopping power when i mash on them. 60-0 feels like instantaneous.
Old Apr 5, 2017, 04:26 PM
Jonno99's Avatar
as said a smear of copper eize in between a shim and pad and a smear in the other side up against the pistons but only a smear so it doesn't fall off into your disc, I also put a little on the pins just for good measure, I have DS2500s and no squeal at all
Tractionlimit
Apr 10, 2011 03:08 PM
Massimo Power
Evo 'For Sale' Suspension / Brakes / Handling
18
Nov 7, 2008 07:37 AM
BoostIt
Aug 17, 2008 02:00 AM
beebers
Dec 15, 2004 10:26 AM
fat_zilla
Driving Techniques
Oct 16, 2002 12:38 AM
Quick Reply: question on brakes
