EVO X AWC Service Required light
Don't think a "service required" notification is quite as simple as the regular service reminder for oil changes.
You can check your fluid level (inside trunk on passenger side), but you might want to check the dealership about that one..
https://www.evolutionm.net/forums/ev...2008-x-mr.html
https://www.evolutionm.net/forums/ev...red-light.html
https://www.evolutionm.net/forums/ev...awc-issue.html
Good luck.. hope it's nothing major
I just had a shep tranny installed with a twin disc, im sure that wouldnt make it come on...maybe someone with a twin disc or shep trans could pop in here and give some words. Thanks for your help so fast !
Warranty is voided YIKES lmao
Actually you are wrong about that. If they cracked the ACD line on the transfer case when disassembling everything then you have air in the system unless it was bled when reinstalling. No, you won't harm anything by driving it, but I'd get it taken care of because you've lost functionality of the S-AWC system.
Did you have the AWC bled? And was it shep or someone else who installed it? If it wasn't bled I wouldn't drive your car again until it was.
When I had my twin disk on the stock transmission all was good. I had my transmission rebuilt my shep and am upgrading to a triple disk so I'll let you know if I have any issues once that gets in.
Ok I seem on here to check the resivoir in the trunk and I did , it is quite empty. Lol I'm going to top it off and see if that does the trick , do I have to reset the battery or will it reset on its own ?
You aren't understanding what we are saying here. The system needs to be bled. You can't unhook a brake line, and then hook it back up and expect everything to be fine without bleeding the system, right? Same scenario. Going by what you are saying, you've lost some of the S-AWC fluid, and more then likely introduced air into the system. Filling up the reservoir will not take care of the problem. Take the car to the dealer (which is about your only choice) and have them bleed it.
When a tranny and driveshaft is installed the system would need to be disconnected ? I spoke to the shop that did my work and they said there was no work done with that line you guys mentioned
Thanks sorry for miss understanding lol
I can't imagine how one would swap a tranny without disconnecting the hydraulic line from the pump to the ACD. If you paid someone to swap your tranny and they did not put fluid back in the reservoir and bleed the system, they aren't really ready to work on Evos. If they actually gave the car back to you with an empty reservoir and you now have a burned out pump, they owe you a pump.
But there's a good chance you'll get lucky and simply filling the reservoir and bleeding the system (and they need to bleed the ACD and both lines to the AYC) will bring it all back. Take the car to someone who understands the system, even if that means a dealer.
