My 02 OZ Rally lancer. Needs lots more work.
Did u have to cut the wires? And the issue with mime is that it's actually basically stuck in the cat. Its a stock cat and semsor. Me and a buddy could not for the life of us bust it loose.
That makes sense. The car still wants to die after I start it but if I Rev it for a little bit it will run fine. But I think it is that o2 sensor that is bad. I will be ordering a new one (walker) off of rock auto for like 44$ tomorrow. so I should get that this upcoming week and then all I have to do is try and busy that old ****ty one loose...
Hey, I should b getting my downstream o2 sensor soon, but I was just wondering how in the world do I go about rwmov Ing the old one and where does this plug in?? Would like to know before I get it and start working on the issue and can't figure it out. Thanks guys.
And does anyone know if an evo 8 or 9 maf sensor would fit on my car? Mine has a crack on top from interchanging it so many times and it hitting ****. A member on here is selling one for a decent price and a new one is 150$ at least.. thanks again.
Eusgen is correct. Evo 8 MAF will not work without a tune. I got a MAF from a junk yard for about 60 bucks. To get to the plug for the downstream o2, pull the carpet back on the passenger side. If you can get the cat off the car, even if you have to take it off from where it connects to the header you might be better off. Soak the o2 in pb blast and wrench on it outside the car so you can use brute force haha. I had to use a pipe wrench on mine to get it out the 1st time
