baking your lights...
Old Sep 30, 2006 | 05:34 PM
Ralli04's Avatar
i searched but couldnt find much of anything...i know o2thag touched on the subject a little bit when he did his projectors but i wanted to know if anyone had a guide on exactly how to bake your front and rear lights...along with opening them to paint...
Old Sep 30, 2006 | 08:50 PM
graphictor2's Avatar
275 for 5 min they will come apart
Old Sep 30, 2006 | 08:53 PM
hondafan's Avatar
you can also use a heat gun, then removing the bulbs and wiring isn't neccessary.
Old Oct 1, 2006 | 04:56 AM
Myszkewicz's Avatar
I don't think the taillights come apart by baking them. I'm sure I read somewhere that they have to be carefully cut open.
The recipe for the headlights I've always read was to put a pan of water in the oven, heat up to 250-275, then turn the oven off and insert headlights one at a time on a towel (so the plastic doesn't touch the metal rack), let sit for 10 minutes, remove and pull open.
Old Oct 1, 2006 | 07:30 AM
otter's Avatar
EvoM Administrator
Here's the how-to on it.
https://www.evolutionm.net/forums/sh...d.php?t=164714
Mys is correct, tail lights must be cut open and glued back together.
Old Oct 3, 2006 | 04:37 PM
Ralli04's Avatar
then how do you bake them im still a little confused...that helps because i want to paint the casing but i also want to bake them as well soo how would i go about that then? i know o2thag has done it but he hasnt seemed to answer my pm soo idk...but thanks for the link otter
Old Oct 4, 2006 | 12:43 PM
egk-69's Avatar
wtf!? the taillights dont open by baking?
how the heck everybody paint them?
Old Oct 4, 2006 | 06:36 PM
sP33Dy's Avatar
Whats the point of baking them if you have to cut the silicone anyway?! hmmm
I baked headlights in my old car ... I never used an oven, and replaced the silicone with new stuff. They Never leaked, never fogged up, never faded, and they looked great I used a similar process to the link Otter posted. http://www.ozecho.com/diy/bakedlights/
e4on2e5
Nov 22, 2010 04:56 PM
oftheheavens
Sep 26, 2010 08:33 AM
madcow
Dec 21, 2005 10:10 PM
arnold16890
Feb 15, 2005 03:13 PM
