My Short Ram Installed
Old Nov 5, 2007 | 05:05 PM
migs647's Avatar
Originally Posted by chengstar
i know there are brake fluids that are dark smart guy...
No need to be condenscending... I was simply stating a fact.
From all the ralliarts i've seen the brake fluid resevoir has all been yellowish/clear from the factory...either way even if it came blue from the factory, in that picture it looks a bit dirty greenish IMO....
I have blue brake fluid in mine. The outside container is white / yellowish. Blue + yellow can make a green tint. I'm not saying his is blue dyed or not, but I'm saying you can't make a 100% observation from a picture.
Old Nov 8, 2007 | 05:46 PM
yogivrx's Avatar
The DOT (Department of Transport) specs for brake fluids (except DOT 5 - silicone) are for them to be Undyed/Amber.
Many companies add "dye" (blue, green,....) to their brake fluids, so people can see the level in the reservoir.
My opinion, get the fluid tested for boiling point & see if it needs changing.
Color might be a good visual alert to check BUT not be be all.
Old Nov 27, 2007 | 06:35 AM
ericxd's Avatar
so if u buy a SRI, is mandatory to buy heat shield?
Old Nov 27, 2007 | 07:45 AM
fkdrcrs's Avatar
no, but i have seen a couple guys make their own. it doesnt hurt to have a heat shield.
Cknoblett92
Nov 5, 2010 12:32 AM
PCToolsWiki
Oct 12, 2010 12:47 AM
nbc_bjj87
Lancer Aftermarket Forced Induction Tech
Jun 9, 2010 10:44 AM
xLancer_Beastx
12
Jun 22, 2009 05:28 PM
FastOZLancer
Lancer Engine Tech
17
Apr 2, 2004 12:48 PM
