Turbo Project!!!!
hows the cooling going with that cause when i used to built civics, blocking that small radiator anylittle bit or putting an intercooler in it was always a risk in overheating and cooling issues, what about fans did u use the civic ones 2 for that??
yep it gets a little hot going up hills but other than that it doesnt gets hot and im using one thin fan for the civic radiator dont know if is a civic one but it blows hard
ok so i was going in the right direction i wasnt sure about that i have a new spare aluminum rad for a civic laying around ill put it to use with my set up when i finish still not sure about tunning im ether going with my microtech witch i have the hand controller and i know my way around or, look into the emanage cause i just saw that post that oddball cracked it for the RA sooo. but i think ill lean more twords my MTlt10. i already have it so why not, if there is anythin els you might think i need to know b4 i go further pm me.
ya about that battery to i just dont think a 200$ battery is worth not saying its not good but its the same tech into that batt as a norm one and that means they still have the tendency to dump and crap out on you and for that amount you might aswell go for the carbon fiber battery.
http://www.brailleauto.com/productca...42_general.jpg
ok where did you hide the MAF i dont see it in the pictures at all? did you illiminate it? somthing is weird here. what system did you settle on? is it tuned? how's it running.....
Well I had the maf before the turbine just like rrms kit but had rough idle and even in times it would turn off cuz of having the bov to the atmosphere so I had to relocate it after the bov, between the intake manifold and the bov (pressurize it) and now it is just fine, ill take some pics...
