04-06 Ralliart Aftermarket Forced Induction Tech (aftermarket turbo/supercharger related topics)
CrAnSwIcK's 4G69 Build: Phase 2
Old Mar 30, 2012 | 05:38 AM
  #211
roblaza's Avatar
Originally Posted by CrAnSwIcK
lol...you're even more impatient than i am...and i'm dying to get this thing under the hood...
I am very impatient. I can afford to build mine right now, so yours is all i have... lmao
Old Mar 30, 2012 | 05:39 AM
  #212
roblaza's Avatar
Originally Posted by lanzerralliart
Very nice cranswick
The best thing next to having a tool, is having a friend with said tool
I wanna see that 12 second time slip
12 seconds... Doesnt that mean he needs to learn to drive first??
Old Mar 30, 2012 | 05:50 AM
  #213
lanzerralliart's Avatar
EvoM Super Moderator
Ooooooooooo hell no cranswick. You going to take that ? Lol
Old Mar 30, 2012 | 07:07 AM
  #214
roblaza's Avatar
Old Mar 30, 2012 | 07:18 AM
  #215
getsideways's Avatar
I Posted in here a while back asking about what these engines can hold.
This is my break in tune on an evo9 turbo 22PSI falling to 15, 4G69 block Wisco/howard/stock crank, Mivec evo9 head Enjoy!
Hope this inspires you a little!
Old Mar 30, 2012 | 07:31 AM
  #216
roblaza's Avatar
What are the internal mod?
Old Mar 30, 2012 | 11:52 AM
  #217
CrAnSwIcK's Avatar
Very nice cranswick
That's a pretty tall order for this stage of the build...maybe when i build a block, get some 660cc injectors, a big 16g, and run closer to 20 psi, with some slicks....I'm hoping for low 14's high 13's for "stage 1" of phase 2
says the guy who wussed out on our track meets last year
took care of it...
very nice...did you have the oil squirter ports machined into the block? some argue it's very important to keep the pistons cool when you start cranking the boost, but others who have done 4G64 swaps have skipped on the oil squirters...keep us updated, i'm very interested in what the block will handle as is...in the future i'll be looking at a spare block, that i will build up with strong aftermarket internals...
Old Mar 30, 2012 | 12:11 PM
  #218
I didnt use oil squirters, there is plenty of oil being tossed about to keep it on everything, and ill be using primarily E85 so im not too worried about piston temperature. I did consider it since i do road racing but im not after big power or boost at the road course. My road course tune will likely 'only' be around 24PSI and 450WHP even though similar setups to mine can make 600+WHP.
Im still nervous being one of the first people to push this block...
To the other internal question that i think was directed at me Its using Stock crank, Howard/MAP rods, Wiseco HD 10:1 pistons. BS removed.
Didnt mean to derail your thread cranswick just wanted to continue inspiring progress!
Old Mar 30, 2012 | 01:31 PM
  #219
CrAnSwIcK's Avatar
still on on track, no worries...
Old Mar 31, 2012 | 07:46 AM
  #220
Just so your aware , the 4g69 has been successful at 30psi and over 500whp , so no need to worry about strength
Sorry crans , I just wanted to inform him on that, to relieve some worries.
Old Mar 31, 2012 | 10:38 AM
  #221
Where did you find that info? This summer i will be running it to the max of the turbo which will be around 35PSI and 600WHP just not daily at those levels, Ive only found half completed builds, and i know of another MUCH higher powered 69evo thats probably nearly finished...
Old Mar 31, 2012 | 12:37 PM
  #222
CrAnSwIcK's Avatar
Well well well...i'm going to have to interrupt your hijack here....
Let the drooling begin...Rob, this one's for you
So as promised, went in for welding the charge pipe today, i'm not going to go in depth with the fabrication, since i did all the measuring, alignment and cutting on my own time in my garage/basement, so today's trip to the shop was strictly a welding session, if you have any questions, feel free to post, so without further ado, i present you with the last puzzle pieces...that's right folks, my sub $1,500 turbo kit is complete as of this afternoon, thanks again to Roy, my welder extraordinaire...feast your eyes...
*insert drum roll here*
Old Mar 31, 2012 | 12:41 PM
  #223
roblaza's Avatar
It's still not installed...close but no cigar for you.
Old Mar 31, 2012 | 01:22 PM
  #224
CrAnSwIcK's Avatar
you're so high maintenance...worse than my wife for god's sake...
i can't install it until Hackish provides me with a ROM so i can run the 3-Bar MAP sensor and 440cc injectors...then i just need to install it, shouldn't take more than a couple hours and a few beers...
Old Mar 31, 2012 | 01:40 PM
  #225
roblaza's Avatar
I don't like being strung along, so get to it already. Lmao
