just finish the RRM clutch line
Originally Posted by bigdoggy_dog
Wow kondo. I just noticed that you have a lot of mods on your car. How long have you been driving it? I'm only surprised because you said it was your first stick. I figured you would be more focused on learning to drive it than mod'ing. But I'm probably just jealous because you already have everything that I want.
well I decided to go out to sac raceway instead and I took all the crap out of my car and the spare tire and of course when I got there it was closed, this is three weeks in a row I swear it only has rained on wednesdays. Oh well I will do the clutch line tomorrow. could someone explain how to get the old fluid out?
It took me two days but I got it on. Fist I striped one of the 10mm nuts on the stock clutch line so I had to go to sears and get a tool to get the nut off. Then I had to figure out how to bleed the clutch line. It goes like this you get a clear tube and a clean 20oz bottle, put on the new line then put a 10mm closed end on the nut then put the clear 3/8 inch hose on the nipple. open up the valve and then push the clutch down and hold it. Then tighten the nut and let the clutch up, repeat this process about 10 times then leave the valve open and pump the clutch about 5 to 10 times the whole time keep refilling the fluid. Then go back to open in and closing the valve unitll there are no more air bubles comming out and you will be done. The new line made a huge differece it engages much quicker and way easier I would recomend this to anyone, I dont know why it does not come stock like this.
Nick
Nick
Nick
Nick
You really have to be careful to make sure that you got a buddy to keep putting fluid into the master cylinder, since it looks like it's full but there is a huge bubble in the bottom, that will flow up when you put fluid in it..
-joe
-joe
stripped hardline
Kondo,
I too have stripped the 10mm nut on the hard line. What kind of tool did you buy from sears to get the nut out. Can you describe it for me? This job seems like a piece of cake until you run into something like that. I'll be looking for your answer.
rallyboy
rallyboy
I was using crappy tools, To get the nut off that I striped I had to cut the hard line and the tool was a 4 piece set thats $20 it says its for rusted or rounded nuts. The outside looks like a wheel lock but the inside is threaded like a drill so you screw it in to the nut and then you can back it out. I still have not figured how the heck you get the nut out of the tool once you are done though.
bruce988jl
04-06 Lancer Ralliart How To Requests / Questions / Tips
Jul 23, 2008 02:24 PM
