04-06 Ralliart Engine/Drivetrain (no forced induction)
Took the RA to the track
Old Jan 10, 2005 | 08:16 AM
DallasN2O's Avatar
It ran 15.3 @91.1 mph with 2.4 60'. Yes 2.4 sux but I did manage a 2.3 and couldnt find second gear both times. The car is still completely stock, all I did was remove the donut and jack from the trunk. I ran off the bottle but next time I will be spraying so I'll keep you guys updated. I'm guessing with intake, full exhaust from RRM, some good tires, and the 50 shot, the car will be doing 14.0 all day. Guys just FYI, second gear is a ***** to get in at high RPM!!! I can get all the details from the time slip if anyone is interested.
Old Jan 10, 2005 | 08:55 AM
BlackLab's Avatar
With a 2.0 or 2.1 sixty, you'd have been in the 14's stock - not bad! Looking forward to seeing your results on the spray next time. Beg borrow or steal a set of drag radials - you're gonna need 'em!
Old Jan 10, 2005 | 09:06 AM
DallasN2O's Avatar
How people get 2.0 sixty is beyond me. I tried everything and could only muster a 2.3.. but I think the revs were higher that time so thats why I couldnt find second. I think I'm gonna change out the trans fluid to something a little more race inspired.
Old Jan 10, 2005 | 09:33 AM
Daddymac's Avatar
So your 15.3 was w/ a 50 shot I take it?
Old Jan 10, 2005 | 10:32 AM
DallasN2O's Avatar
The 15.3 was all motor.
Old Jan 10, 2005 | 11:01 AM
sillypuddy's Avatar
i always thought track = road course
isn't that called a drag strip? =)
-joe
Old Jan 10, 2005 | 11:41 AM
DallasN2O's Avatar
Depends on where youre from.. Canada is a long ways from Texas.
Old Jan 10, 2005 | 11:50 AM
Freddie1111's Avatar
I have to check to make sure...but I think Motortrend got the same 60' time as you in the Feb comparo test - so not bad. I don't think you can get much better with the crapola tires we have.
Old Jan 10, 2005 | 12:02 PM
DallasN2O's Avatar
I should have let out some tire pressure for the first run I'm sure it would have done better. After the first run the track went to crap, were about 100 import street cars there dragging dirt and air conditioner sweat onto the track. I have the Potenza's btw.
Old Jan 10, 2005 | 01:13 PM
Eclipse2Lancer's Avatar
air conditioner sweat in January. Go ahead...rub it in.... .....you live in a warmer climate while most of us are freezing.....especially up in Canada!
Old Jan 10, 2005 | 02:58 PM
Lightfighter's Avatar
Its usually 60's to 70's here during the day.
Old Jan 10, 2005 | 03:41 PM
blk-majik's Avatar
its 80 here today =) suckers! kinda sucks tho. engines run hot
Old Jan 10, 2005 | 03:44 PM
Alchemist's Avatar
If you want to find 2nd, you need to get at least a firmer front motor mount and then redo the entire shifter system: go to a short shifter, replace shifter base bushings and both underhood bushings. You'll be shifting crisper and faster all day in every gear!
Old Jan 10, 2005 | 04:51 PM
Arithmetic's Avatar
very nice times, yeah... if you get that 60 down, ull see high 14's. Motortrend mag mustard a 14.9 @ 92mph I believe. Some RA owner here did a 15.0 w/ just an intake and short shifter and on stock tires.
Old Jan 10, 2005 | 06:27 PM
reimundo's Avatar
cool man keep it up.
