04-06 Ralliart Engine/Drivetrain (no forced induction)
Custom made Ralliart Intake
Old Jun 7, 2005 | 05:05 AM
  #46
MitsuJoe's Avatar
Just pull your negative battery cable for 10 minutes and that will reset the ECU. Then make sure to go drive it hard after that so you give the ECU a more advanced timing map.
Thanks for the comments, I try my best!
Old Jun 8, 2005 | 08:09 AM
  #47
Rydog's Avatar
oh that's it? cool. so after you did that you found that the intake was sucking in air all the way thru the powerband?
Old Jun 8, 2005 | 09:35 AM
  #48
MitsuJoe's Avatar
Yes it helped smooth things out a bit, the engine/ecu had to relearn how to suck in air which seemed to smooth things out.
sotheby
Lancer Troubleshooting
12
Apr 15, 2020 08:52 AM
chaotichoax
Apr 12, 2020 11:55 PM
tucknroll
Mar 25, 2016 08:03 AM
EvilTechnology
Jun 24, 2015 09:22 PM
commbubba19
May 9, 2015 03:46 PM
