04-06 Ralliart Engine/Drivetrain (no forced induction)
Piggyback software
Old Jul 23, 2007 | 04:27 PM
  #61
DangerousDan's Avatar
which wire are you using? you can get the signal from two places for the tach, straight from the tach signal wire or from the crankshaft sensor wire. either way you need an o-scope to set up the sensors from scratch, or you have to know what the square-waveform is supposed to do.
two big issues with our car and piggyback units: the tach signal is difficult to read from the sensors either because the signal strength is low or because the signal is abnormal(not sure which at this point, my SMT unit arrived defective,) and the MAF sensor is a karmen vortex type that operates on frequency instead of voltage. well, that's two that relate to your question.
Old Jul 23, 2007 | 04:35 PM
  #62
Jessie55's Avatar
figured it out ok for some unknow reason even after i save my settings in the piggy as a 4 cyl it changes it to 6 next time i start my car...odd....when i change it to 4 rpms are read perfect so now i guess i will read my manual a bit more and scan some forums
isn't it so fun how everything always works so well in theory...the joys of working with cars
Old Jul 23, 2007 | 04:47 PM
  #63
Jessie55's Avatar
prob solved my stupidity lol
Old Jul 23, 2007 | 05:24 PM
  #64
post up a DIY man! no one has done with the safc what you have done for themselves, only had others do it for them
Old Jul 23, 2007 | 07:17 PM
  #65
Jessie55's Avatar
well there is already all the info required in my other post where i begin by pleading for help but if enough people want i could make a diy i guess....yes or no
lol its kind of funny though i got it all set up but i cant tune until i get a wideband and right now until i moove im on a bit of a budget so no tuning yet dam
Old Jul 24, 2007 | 03:43 AM
  #66
yeah, the software settings and some various screenshots would make it simpler to understand. the wiring diagrahm was A+ though.
Old Sep 24, 2012 | 08:17 PM
  #67
Timbolo's Avatar
Hello Face
I recently installed the Road Race Piggy back and zeitronix wideband on my 04 Ralliart. I am not able to data log my RPM or TPS through the software and I can't connect to my ECU through the Split second program. It attempts to connect through com port 6 but says "unable to connect to ECU."
Can anyone tell me the process of connecting and datalogging? Any help would be great.
Thanks
Old Sep 24, 2012 | 08:27 PM
  #68
AdamRA's Avatar
How are connecting straight serial or usb / serial cable ?
nj1266
Jan 25, 2026 01:43 AM
Sicktght311
Lancer Aftermarket Forced Induction Tech
42
Mar 30, 2018 01:13 AM
xPRimNT
239
Jun 2, 2016 10:40 PM
DangerousDan
Aug 10, 2007 07:00 PM
ROCK
Lancer Engine Management / Tuning Forums
63
Dec 12, 2005 09:44 AM
