04-06 Ralliart Engine/Drivetrain (no forced induction)
Piggyback Maps
Old Jun 20, 2007 | 03:34 PM
  #106
ROCK's Avatar
wIDEBAND IS IMPORT FOR SURE. Don't cheap out now. You are gonna regret that.
ROAD/RACE
Old Jun 20, 2007 | 03:45 PM
  #107
DangerousDan's Avatar
+1 good advice, can't beat the safe feeling it provides know your AFR's are perfect
Old Jun 20, 2007 | 03:59 PM
  #108
LePaGe20's Avatar
if i take a map with a same mod he have and i have it's ok...its the same mod ...the difference i have a downpipe and me i have a headers-downpipe with a Cat..
Old Jun 20, 2007 | 04:11 PM
  #109
LePaGe20's Avatar
What is the good ?
PSC1-001 Programmable Signal Calibrator w/Absolute MAP sensor
PSC1-002 Programmable Signal Calibrator
PSC1-003 Programmable Signal Calibrator
PSC1-004 Programmable Signal Calibrator AFM to MAF
PSC1-005 Programmable Signal Calibrator AFM to MAF w/Inv. Output
PSC1-006 Programmable Signal Calibrator Karman to MAF
PSC1-008 Programmable Signal Calibrator -- Late Model GM
PSC1-009 Programmable Signal Calibrator AFM to MAF HV Output
Old Jun 21, 2007 | 04:37 AM
  #110
we have a karman type MAF sensor. RRM had to work with split second when the 4g69 first came out to get a unit made for us, so I am not sure if you can buy the split second unit from them or if you must get it from RRM.
split second=overpriced for the features you get, imo
Old Jun 21, 2007 | 08:33 AM
  #111
ROCK's Avatar
The ones for Mitsu are private label. THey are made just for us. Need to get them here. None of the numbers above are correct.
ROAD/RACE
Old Jun 21, 2007 | 08:51 AM
  #112
thanks alot mitsu
Old Jun 28, 2007 | 05:18 AM
  #113
LePaGe20's Avatar
i installes my piggy and when I pedal in does it I crosses… when I roll normally it's correct, I would like to have a basic chart to be save while waiting To have a wideband…
Old Jun 28, 2007 | 05:25 AM
  #114
désolé mon ami, mais votre anglais est trop cassé pour comprendre, essayer la traduction de poissons de Babel par altavista.com comme j'ai fait ici.
Old Jun 28, 2007 | 05:30 AM
  #115
although I doubt that translates well into French
Old Jun 28, 2007 | 05:34 AM
  #116
LePaGe20's Avatar
i installed my piggyback ....When I press on the pedal has gas with the end he cut ....so when i run normally it's ok.....i want a Save map for my mod... CAI downpipe/headers Pulley.....while waiting for the wideband
it's correct ?? my english ??
Old Jun 28, 2007 | 06:00 AM
  #117
what you are describing here is unclear.
ce que vous décrivez ici est peu clair.
with your mods the base map from RRM "is supposed to be" safe. this map has MORE fuel than the RRM base map, in all areas, and "will" be safe at your temps/elevation with your mods. you are responsible for your own vehicle, however, and I recommend a wideband or a trip to the dyno to verify your AFR's are safe before pushing the car.
avec vos mods la carte basse de RRM "est censée être" coffre-fort. cette carte a PLUS de carburant que la carte basse de RRM, dans tous les secteurs, et "" sera sûre à votre temps/elevation avec votre mods. que vous êtes responsable de votre propre véhicule, cependant, et je recommande une bande large ou un voyage au dyno pour vérifier votre AFR sont sûr avant de pousser la voiture.
Old Jun 28, 2007 | 06:04 AM
  #118
yeah, babel fish needs some work, at least with french to english. I really hope you are understanding what I am telling you
Old Jun 28, 2007 | 06:12 AM
  #119
LePaGe20's Avatar
this map is not complete ...
Old Jun 28, 2007 | 06:14 AM
  #120
LePaGe20's Avatar
i have not 61 case ???
