04-06 Ralliart Engine/Drivetrain (no forced induction)
Researching AWD Conversion
Old May 19, 2007 | 06:42 AM
  #196
JLLancer8's Avatar
so 03 outlanders have the same sub frame and sorry to use "junk"....... would i have to get new control arms then cuz of the axles then.... i found a wreck outlander for 1900 online but it looks very very bad so the underbody might be gone......................... now that i thought of it too does the 03 have the mivec motor cuz then i could just build motor, take suspension, and turbo all at once .
i had a dream about this last night......... my underestamated car wasting my buddy's vette
Old May 19, 2007 | 12:12 PM
  #197
Diavlo's Avatar
If you need parts check out the mitsubishi section of http://www.vw-auto-parts.com
Thats where I get my new parts from. Not everything is expensive.
Old May 22, 2007 | 12:42 PM
  #198
JLLancer8's Avatar
http://www.trademotion.com/partlocat...?siteid=213714 this is a discount of the same stuff.
Old May 22, 2007 | 12:50 PM
  #199
JLLancer8's Avatar
so for the rear spension what do i need??? the trailing arm and is that it or do i need the control arms too. see my rear end bushing are shot and i need to replace them............... so i don't want to buy thing for this suspension then go to the outlander one later and waste money.....
Old May 22, 2007 | 01:08 PM
  #200
Diavlo's Avatar
Sorry, I think you've misunderstood. The Trailing arm for AWD will NOT work for FWD also. The whole point of me getting the new outlander trailing arm, is because the Lancer one (and the FWD Outlander one) uses a built in spindle (fake axle) to attach the hub to. The AWD Outlander one has a big hole for the wheel bearing and real axle.
You'll have to buy the NON-AWD trailing arms (Lancer or Outlander) otherwise you wont be able to re-attach your hub unless you actually have AWD.
Old May 22, 2007 | 05:10 PM
  #201
JLLancer8's Avatar
thats is what i thought, thanks, but do you need control arms too or just the trailing arms........ just like you i want to start getting parts....... i'm so convinced this will work by reading your other posts
Old May 29, 2007 | 05:53 AM
  #202
Diavlo's Avatar
The final batch of parts arrived today. All I need now is the tranny and I can start work!
Today I got: Front Axles and output shafts, Rear Hubs, Rear Wheel Bearings, ABS Sensors, AWD Tranny rear mount, various nuts and bolts.
Rear AWD tranny mount (only one that differs from FWD)
Rear Hub with spline for axle.
The whole lot!
Front Axles and Output Shafts!
Old May 29, 2007 | 07:35 AM
  #203
Eclipse2Lancer's Avatar
Can't wait until you start on this.
BTW -- your carpet is fantastic!
Old May 29, 2007 | 01:08 PM
  #204
JLLancer8's Avatar
just wondering if i get a evo 5 speed trannyand transfercase, it fits right???? and if it does what about the rear diff gears........ would i need a outlander one or evo so they rotate the same speed???????
Old May 29, 2007 | 04:38 PM
  #205
Diavlo's Avatar
I guess that depends on whether the current 4G63 block is the same as the Evo 5 one. There have been a couple of alterations to the 4G63 over the years.
Old May 30, 2007 | 01:01 PM
  #206
JLLancer8's Avatar
cause my buddy just put a evo 6 speed into his 1g dsm....... i know the 4g63 has a 6 bolt on the old 1g and a 7 bolt on the new 2g, but i'm not sure on evos and i haven't been able to get the the shop to ask about it
Old May 30, 2007 | 01:53 PM
  #207
Maikumaru's Avatar
dosnt a ralliart have a 4g69 engine? I would assume that the tranny for the 4g63 would simply not "fit" the 4g69...
honestly let Diavlo continue this thread...if you are going to put an EVO tranny on your ralliart...either start a new thread or buy a (insert AWD car here).
He has been very clear what is needed, and has included parts list earlier in the thread...
Old May 30, 2007 | 03:10 PM
  #208
Diavlo's Avatar
I've just checked and the Evo tranny wont fit unless you custom mount the starter motor. The rest is the same because it is the 4G6x block.
The Ralliart start motor is at the front top, and I believe the Evo starter is front bottom.
Old Jun 18, 2007 | 09:32 PM
  #209
just _a_oz's Avatar
good luck with the conversion I also aspire to do the same, screw those guys "just by an Evo" not to spark a debate because we all know that the Evo is a great car what I don't like is that some owners just bought the car and think they're the shiznit for having a fast car that they just got a loan for. There is no passion there, I mean in time I'm sure their will be but for the most part no passion, it's like back in the day when people with civics would smoke a car that's waaaayy more expensive and it's a good feeling. Not to mention that your insurance and payments for an RA or OZ will be alot less than an Evo's payments
Old Jun 19, 2007 | 07:34 AM
  #210
Diavlo's Avatar
Encase anyone is wondering Ive scheduled to order the transmission on August 1st. Thats the last part I need.
In the mean time I've got to find some new Rims to match the new 5x114.3 bolt pattern at the rear.
