04-06 Ralliart Engine/Drivetrain (no forced induction)
Researching AWD Conversion
Old Apr 26, 2007 | 07:35 PM
  #151
Ryan_VRX06's Avatar
They did that for the Evo IX in that Tokyo Drift movie so it could smoke tyres easily to appeal to hoons and also so it drifted like an FR. (those movies are all corny nonsense I know, but I still love em). Mechanically it was mostly stock.
Old Apr 26, 2007 | 09:09 PM
  #152
sP33Dy's Avatar
BUt, as mentioned, they did it with ease in Tokyo Drift possibly by removing a Fuse ---- removing a fuse in the R32 GTR Skyline will simply stop the frotn diff from working because it's electronically, so it'll then switch to RWD. A lot of people dyno GTR's and even 4wds as RWD when only a 2wd dyno is available. Whilst AWD is engaged, computers control the bias for maximum grip and all that? The Outlander (as also mentioned) is 100% mechanical --- therefor AWD fulltime, i believe.? So no ... it wouldnt be as easy to make a RWD Lancer using an Outlander drivetrain --- the new model outlanders however may be a different kettle of fish.
Old Apr 26, 2007 | 09:45 PM
  #153
silversleeper's Avatar
Actually if I am not mistaken and I will have to pull my DVD out and look at the extras and making of the movie, I think they removed the front CV axles for that movie to make it rear wheel drive only. I dont think you can just pop a fuse on an evo and make it rear wheel drive. I think its set up as a front wheel drive car and then uses the rear for suport, not the other way around. Remember the older evos came with the same drive train as the outlander did sooooo I wouldnt really complain about it. I would like to have a mechanical AWD anyways since there would be less to mess with when the time comes to mantain it ect. Just my 2 cents worth.
Old Apr 26, 2007 | 11:53 PM
  #154
Ryan_VRX06's Avatar
Yeah thats how I remember it, mechanically not electronically making RWD
Old Apr 27, 2007 | 01:48 AM
  #155
Diavlo's Avatar
Here is the transfer case, prop-shaft and Rear Differential I receieved today.
These parts were off an 03, Whereas I'd intended them to be from an 04-05! Luckily it seems the transfer case is identical even when the engine was 4G64, and there is also no difference, physical or ratio-wise between manual and auto either.
Old Apr 27, 2007 | 02:21 AM
  #156
MITVRX's Avatar
Diavlo, you are a mad man!
Old Apr 27, 2007 | 08:29 AM
  #157
PR_Mivec's Avatar
Thsi Is Severe Love For A Car... I Admire You My Friend...
Old Apr 27, 2007 | 08:36 AM
  #158
Tom-05-MR's Avatar
RMR supplied the hardware to convert the Tokyo Drift Evos to RWD. It was not a matter of pulling a fuse. It sounds like an awful way to go, really: RWD with the weight distribution of FWD.
Old Apr 27, 2007 | 09:12 AM
  #159
migueralliart's Avatar
Diavlo you like a young Mac Guiver (you can do almost everything) heheh keep us updated
Old Apr 27, 2007 | 02:14 PM
  #160
MITVRX's Avatar
Migue check your PM!
Old Apr 27, 2007 | 03:33 PM
  #161
Tachyonzero's Avatar
Diavlo, An evo conversion has done already. check "MODIFIED MAG" november 06 issue. A mirage turn to EVOcoupe AWD. All parts are completely evo, no outlandish parts.
http://www.mirageforums.net/viewtopi...641&highlight= and http://www.mirageforums.net/viewtopi...537&highlight=
and mine too : http://www.mirageforums.net/viewtopic.php?t=28486
If you able to complete an evo conversion... I'll might put you to our 4g63 conversion club
Old Apr 27, 2007 | 03:35 PM
  #162
deleted
Old Apr 27, 2007 | 05:36 PM
  #163
outlander001's Avatar
Ralliarts and EVO's are completely different platforms, Ralliarts and Outies share the same platform so it would be easier...
Old Apr 27, 2007 | 10:18 PM
  #164
Diavlo's Avatar
Yeah Evo has completely different rear suspension, Outlander And Lancer is the same except for the crossmember. On the Outlander it has a Dif mount built in and is bolted in. Lancer doesnt have the diff mount and its welded in.
Old Apr 28, 2007 | 11:18 AM
  #165
Juan Martinez's Avatar
Cut that beast out, drill some holes, and bolt that beast in.
