Researching AWD Conversion
The final parts list is now:
Outlander AWD Trailing Arm Left
Outlander AWD Trailing Arm Right
Trailing Arm Bushing x 2
Fuel Sending Unit
Fuel Suction Hose
Fuel Pump
AWD Fuel Tank
Left Rear Axle
Right Rear Axle
Left Front Axle
Right Front Axle
Exhaust Joining Clamps
Exhaust Elbow Peices
Axle Washers & Nuts
Rear Differential Assembly
Rear Differential Support Crossmember
Rear Differential Bracket
Differential Mount Bracket Left
Differential Mount Bracket Right
Transfer Case
Transfer Case water feed hoses
AWD Transaxle Rear Roll Mount
Propeller Shaft Assemly
Rear Wheel Bearings
AWD Manual Transaxle
Each month, I'll be spending 3/4 of my disposable income to get this complete as quickly as possible - but it could take up to 5 months - the rear diff is £1000, transfer is £1000 and the transaxle is £1000 so that is 3 months there, but everything else is ok. Im anticipating 6 months until work starts. Ill post photos of the parts I recieve, and give you an updated list, because I know one of the worst things on EvoM is when someone says they are gonna do something - then go quiet and maybe never hear of it again.
A rough plan for parts buying is as follows:
Month 1 (Already Bought and on its way):
Trailing Arms
Fuel Sending Unit
Trailing Arm Bushings
Rear Left Axle
Rear Right Axle
Month 2:
AWD fuel Tank
Fuel Pump
Front Axle Left
Front Axle Right
Transaxle Mount
Transfer Case water hoses
Month 3:
Propeller Shaft
Diff brackets
Month 4:
Transfer Case
Month 5:
Rear Diff
Month 6:
Transaxle
Fuel Sending Unit
Fuel Suction Hose
Fuel Pump
AWD Fuel Tank
Left Rear Axle
Right Rear Axle
Left Front Axle
Right Front Axle
Axle Washers & Nuts
Transfer Case
Rear Wheel Bearings
Trailing Arms
Fuel Sending Unit
Rear Left Axle
Rear Right Axle
Month 2:
AWD fuel Tank
Fuel Pump
Front Axle Left
Front Axle Right
Transaxle Mount
Month 3:
Propeller Shaft
Diff brackets
Month 4:
Transfer Case
Month 5:
Rear Diff
Month 6:
Transaxle
Which area will you start on first? Rear crossmember mounting, fuel tank, transmission? I would assume you would see about getting the rear crossmember installed, the the suspension and get it to driveable condition again before you mount the rear dif. Right?
Never accelerate hard in the wet, thats how evos end up wrecked, because noobs think AWD makes them invincible. I would hate to see a project like that ruined because you accelerated and lost control. Good luck with the project.
Like others have said, Daivlo you've been one mother ****ing crazy inspiration to many here, good luck on the AWD conversion.
And I agree with Karta, since there is nothing like what you will have done, don't **** it up after!!!!
Cheers
Cheers
