04-06 Ralliart Engine/Drivetrain (no forced induction)
Cylinder Head project !!!
Old May 2, 2007 | 11:44 PM
  #61
migueralliart's Avatar
I ordered from the mitsubishi dealer 12 bucks hehehe
Old May 3, 2007 | 08:04 AM
  #62
PR_Mivec's Avatar
Originally Posted by MITVRX
Was that sarcasm or ..?
You can never tell on the internet these days. I think "im sureeeeeeeeee you will" or "im 'sure' you will'" falls in the category.
Okay anyway, back on topic!
no sarcasm here
Old May 3, 2007 | 08:37 AM
  #63
Blitz19's Avatar
I'm pretty sure u can make it...if u go standalone maybe it's an easier task than with piggy...
Old May 3, 2007 | 09:31 AM
  #64
Well I don't want to go stand alone even thou the emanage ultimate it's pretty much a standalone almost , it has SOOOOOOOOOOOOOOOOOOOOO many features /// either way I will keep you guys updated in the progress ,,,,
Old May 3, 2007 | 10:54 AM
  #65
boozeup&riot's Avatar
Help educate a noob on a little off-topic question please. I'm looking to purchase a second cyl head as well, I checked car-part.com and all I could find were galant heads. Anyone know of any other place to pick one of these up?
Thanks in advance!
**update**
I have found some outlander heads, these are identical unless im mistaken.
Old May 3, 2007 | 11:05 AM
  #66
Dude the Galant cyl heads are the same as the Ralliarts it HAS to be a 2.4 MIVEC 2004 + galant thou, don't try the intake manifold I was told it IS different
Old May 3, 2007 | 12:06 PM
  #67
ralliart329's Avatar
^^also the new eclipse 4cyl. are our engine too.
Old May 3, 2007 | 12:07 PM
  #68
I think the head from the eclipse might be different cause it has direct injection, can somebody verify this??
Old May 4, 2007 | 12:04 AM
  #69
Henrys Ralliart's Avatar
i guess what i ment to ask is how did you make gasket larger to match larger port sizes. Also what are you going to do for headers to match enlarged exhaust head ports. Forgive all the noob questions but i wanna do some head/cam work to my car and really dont know where to start or what my options are (other than rrm)
Old May 4, 2007 | 12:28 AM
  #70
well I didn't enlarge the stock gasket , stock gaskets have larger ID than the ports. You enlarge the ports up to the gasket size to improve flow , I will make a custom header later on, I believe the only one that's doing a 1-3/4 header (runners) is RPW which ACCOLADE sells. I don't suggest to buy RRM cause it is 1-1/2 and that's the stock exhaust port size .... Better to go with 1-3/4
Old May 4, 2007 | 12:27 PM
  #71
UPDATE !!! FORGOT TO post some pics on the sexiest bronze valve guides I've seen
THIS IS how you SHOULD build cyl heads with top of the line parts , not just steel stock valve guides and seals. This is presicion stuff here heheheh....
I will get these and the valve seals COATED with a special lubricant ....
The valves will be coated with ceramic thermal barriers along with the exhaust ports and the combustion chambers .. will post some pics before and after
PS My kung fu is strong .......
Old May 4, 2007 | 05:06 PM
  #72
migueralliart - thanks for the info man, I had NO IDEA they were the same head. I assumed they weren't due to MIVEC, shows how little I know. Thanks for all the info and being so open about what you are doing, and how.
Old May 4, 2007 | 05:15 PM
  #73
lanzerralliart's Avatar
EvoM Super Moderator
man you are taking off on this if you keep this up I might decide to stay n/a...well, n/a ish,(80 wet shot)....
Old May 5, 2007 | 01:10 PM
  #74
Eclipse2Lancer's Avatar
Those valve guides look like bullets!
Old May 5, 2007 | 05:46 PM
  #75
MITVRX's Avatar
^ Maybe they are..
