04-06 Ralliart Engine/Drivetrain (no forced induction)
EGR elimination !!
Old Jun 9, 2007 | 03:57 AM
  #61
drewbad's Avatar
You're welcome. Dan, I hope you're not feeling too broken this morning! hehehehe!!
Migue, I will send you the spare valve so you can take it from here. I have your contact info.
I'd be interested to see what others would have for this topic too.
Drew
Old Jun 9, 2007 | 07:14 PM
  #62
DangerousDan's Avatar
nobody else cares I was a little under the weather, until about 11AM
Old Jun 12, 2007 | 08:47 AM
  #63
outlander001's Avatar
Sorry guys, i get lost after the
So it works or not?
Old Jun 12, 2007 | 09:05 AM
  #64
not sure yet, we are done investigating possibilities but have to wait on migueralliart
Old Jun 12, 2007 | 09:21 AM
  #65
migueralliart's Avatar
Drew removed the little piece that pushes the valve and ran the car for a while with NO CEL light ... again I will do some more advance testing soon
Old Jun 12, 2007 | 09:41 AM
  #66
PR_Mivec's Avatar
interesting.... i should have done that.. i just plated the thing and eliminated the valve...
Old Jun 12, 2007 | 09:45 AM
  #67
drewbad's Avatar
PR_MIVEC, are you getting a CEL error?
Old Jun 12, 2007 | 09:47 AM
  #68
PR_Mivec's Avatar
i do but is not related to the egr...
system rich at bank 1
Old Jun 12, 2007 | 10:08 AM
  #69
That sounds so NEBULOUS as always , when you see a guy in PR that has his CEL on please proceed with CAUTION
Old Jun 12, 2007 | 11:43 AM
  #70
PR_Mivec's Avatar
that hurts
Old Jun 12, 2007 | 12:35 PM
  #71
Blitz19's Avatar
lol I have a cel on 2...an my RA runs fine!! :P
Old Jul 7, 2007 | 05:13 PM
  #72
boozeup&riot's Avatar
so, bumping an old thread:
there was talk of removing the piece that moves the valve, but was it ultimately determined it would be best/easiest to just plate the thing off and put the valve back on so the ecu thinks its still moving the valve, so no CEL...right?
Old Jul 8, 2007 | 01:09 AM
  #73
Myszkewicz's Avatar
Probably. It's easier to reverse that way, too.
Old Jul 8, 2007 | 11:06 AM
  #74
bruce988jl's Avatar
from what i'm getting from reading this thread... The no-CEL wasn't confirmed after driving the car for more than 50 miles. But the block did work, however it might make the engine block hotter?
Old Aug 14, 2007 | 10:11 AM
  #75
The exhaust gas is routed along side a coolant channel in the head. While blocking it from the EGR side will eliminate a good deal of heat from your intake air in #4 it will still transfer heat to the head. the #4 exhaust port has a slit cut into it, that leads to the hole that goes through the head. I have taken quite a few pics of this, and will include it in my final writeup(whenever that happens, I can't even finish the car ) If you can block it from the exhaust side you will definitely get a decrease in head temperature. I was thinking about getting a piece of rod with the same OD as the hole and bending the end to fit in the channel. This would block the exhaust from the exhaust side of the passageway instead of the intake side.
I did find out more information during my research this week though. The EGR valve is checked by the MAP sensor. Apparently the EGR opening changes the vacuum pressure slightly, and if the MAP sensor does not see this change it will throw a CEL. I am not sure how accurate this is, but it makes sense to me. something to keep in mind when testing this anyway.
