04-06 Ralliart Engine/Drivetrain (no forced induction)
Differential compatibility?
Old May 28, 2008 | 01:17 PM
blk-majik's Avatar
I was looking at differential options for the RA and all I can find is the RRM-distributed Quaife LSD. Its probably the best bet, but I'm not done digging yet Our stock transmission is an F5M42-2-F6ND. All the F5M42 variants use the same casing and are very similar, maybe identical. Most changes between the variants seem to be gear ratios. The differential is housed in the casing and connects to the drive shafts. So if the trans is the basically the same, the next major variable for differential compatibility is the drive shafts. If they are also the same, we have a good candidate for swap compatibility. The holy grail would be an car with a stock LSD in a F5M42.
However, as far as I know, our driveshafts are unique to the ralliart. They are a split-shaft, which none of the DSMs, mirages, galants, etc used to my very limited knowledge. But that doesn't mean that the interface of the shaft to the differential is not the same. The part numbers wont match up, but they might actually fit. I'd be surprised if they didn't. Thats what I need some help figuring out.
I know the 2000 and 2001 2.4L FWD Eclipses used a F5M42. The 1997-2001 1.8L Mirages also used them. And it was in the Dodge Stratus ST and SXT. It think it might also be in some galants, sebrings.
As for the Quaife LSD that we might be able to use (and maybe that RRM is offering), I think it may be Quaife model number 76.306.180. Its marketed for the 2000-2005 FWD Eclipse, 99-04 Galant, and 01-04 Stratus. If we can verify shaft computability with any of those, then the only other minor concern i can think of speedo gear and bearing computability. I'd be REALLY surprised if thats a problem.
If we are lucky, this might open us up to using a Cusco clutch-type LSD. They list some for the JDM 87-92 galant (the jap translation actually says 'garant' lol!), 91-95 lancer, and 87-96 mirage. remember, those are all jdm year/models. ours will be a bit different.
Old May 28, 2008 | 05:03 PM
DangerousDan's Avatar
the part number for the quaife is on here some where.
https://www.evolutionm.net/forums/sh...1&postcount=13
Old May 29, 2008 | 10:45 AM
blk-majik's Avatar
err... i typod the model number (there is no 76.306.108). I meant 76.309.108, which is what you posted in the other thread. nice cusco doesn't list any eclipse applications. do they even have an eclipse in japan?
has mitsu ever released a fwd car with a limited slip differential?
Old May 30, 2008 | 09:23 AM
not sure about your ? but credit isn't mine. I merely 19'd the user who posted the info
Old May 30, 2008 | 12:31 PM
Eclipse2Lancer's Avatar
I think the FTO had an optional LSD in Japan. FTO was made between 1994 - 2000.
Old May 30, 2008 | 09:22 PM
gjgfrombigd's Avatar
try searching cyclone. It's hard to beleive that with all the models of JDM Eclipses/Cyclones, there wasn't a FWD LSD in one of them.
Old Sep 19, 2014 | 08:20 PM
RalliartN's Avatar
resurrection - OEM LSD for F5M42 tranny
Can someone give an educated guess if this genuine Mitsu LSD fits our RA's? Looks like it to me. If so, how do I get a p/n to see if it is available for a decent price (under $1k).
http://www.fto-ireland.com/forum/php...php?f=4&t=8480
Old Sep 19, 2014 | 10:58 PM
CrAnSwIcK's Avatar
rather than ASA, which is Mitsubishi motors north America (+PR, guam), get a copy of CAPS (mitsubishilinks.com) and they have other markets like JDM and stuff, so you can pull up many more models than ASA...My friend Ghislain has a copy with some old *** JDM stuff in the database...OEM LSD would be sweet to say the least.
rpm_ruffryders
Lancer Engine Tech
603
Mar 3, 2020 07:04 AM
Skidonner90
Jul 20, 2016 07:49 PM
loch
Jun 19, 2016 03:11 AM
TheMowerman
Apr 13, 2016 05:59 AM
EVOVII_SWE
Aug 8, 2005 03:56 AM
