04-06 Ralliart Engine/Drivetrain (no forced induction)
Calling all Auto Ralliarts! HELP!
Old Nov 8, 2010 | 08:51 PM
Raikiri's Avatar
hm.. okay. from the looks of it it seems like your crank sticks out slightly less than mine does but that could just be my eyes playing tricks on me. that measurement would definitely come in handy for me as i may have to get mine machined down a few fractions of an inch
Once the converter is in that measurement of how far it is as opposed to the edge of the housing would be also a great help to me. I think my converter may not be seated in as far as its supposed to but we'll see i suppose
Looking at this picture:
http://www.flickr.com/photos/5570111...n/photostream/
How in what way do you have the plates flipped? like does the concavity of the adapter go up or down in comparison to the other plate. same with the smaller plate, does the rounded off portion go towards the adapter? or does it go towards the little press in piece?
Old Nov 9, 2010 | 09:27 PM
Resurrected RA's Avatar
In this pic the table would be the crank side, I think...
Take a straight edge across the bellhousing and measure to the highest point on the tourque converter, I will get the factory measurement from the Mitsubishi shop manual tomorrow. The tourque converter may not be seated all the way. The mechanic working on my car figured that was the only issue that there might be with your install. The crank side looks almost identical to what mine looks like.
Old Nov 10, 2010 | 06:45 PM
Raikiri's Avatar
were you able to get those measurements?
Old Nov 10, 2010 | 07:07 PM
I was there again today, no mechanic. They covet that Mitsubishi shop manual, I wasn't allowed to look at it. Tomorrow the mechanic will be in and he will let me look at it.
Old Nov 12, 2010 | 06:50 AM
Raikiri's Avatar
update?
Old Nov 16, 2010 | 12:34 PM
Raikiri's Avatar
::sigh:: just got word this morning that I wil be unable to get the information i needed from R.RA but its okay its not his fault
we're going to go to a junkyard hopefully soon and see what we can find off the auto RA that a friend of mine found there
Old Nov 21, 2010 | 09:47 AM
Sorry aboot that, eh.
This car of mine, "Christine", will be the death of me. I am going to the mechanic tomorrow and talk to him. I am no longer as pissed off as I was a week ago, so I don't think I will punch him out. I will see if the service manual will be available to me, I bet there is a simple explaination to your issue.
Old Nov 21, 2010 | 01:13 PM
Raikiri's Avatar
hopefully cause im going to head to a junkyard tomorrow to get them to pull a crank out of an auto ralliart we found
Old Nov 21, 2010 | 02:25 PM
We used the crank that came with the engine, which was previously mounted to a manual transmission. I think your issue is with the the transmission, check the transmission pump gear.
Old Nov 21, 2010 | 03:43 PM
Raikiri's Avatar
see the thing is. my other mechanic that took a look at the car said that w/ the transmission he's not sure if its that cause he took a look at it and said he can hear the pump n whatnot turning... iono i guess we're just trying to get rid of all other possibilities you know?
I REALLY want to see another auto transmission but w/ this car we found I'm unable to do it cause my mechanic is going to be busy for a good amount of time..
Old Nov 21, 2010 | 10:54 PM
Myszkewicz's Avatar
My guess would be that you have the crankshaft bushing still in place from the M/T, so the one from the A/T isn't fitting into place. Check the pic.
Old Nov 22, 2010 | 01:04 PM
Raikiri's Avatar
I took a look at both bushings, assuming they're the metal circular pieces at the end of the crank, and they appear identical.
Old Nov 23, 2010 | 05:26 AM
AFAIK, the bushings are the same.
I dropped off my expense receipts, $387.00 in total out of my pocket for their negligence. I got pissed off when they said that they were going to charge me for the alternator, oil change, and deductable. After all the **** I went through, they are going to still nickel and dime me! I might call my lawyer, I am again pissed!
SloEvo12
Dec 20, 2015 05:54 PM
Kiju
Sep 1, 2015 03:25 PM
kaj
Aug 6, 2015 02:54 PM
THUB
Apr 1, 2012 08:08 PM
dooby69
17
Mar 17, 2011 06:21 PM
