Need advice on Custom Camshaft
All measurements at 0.05 Tappet Lift
Small Lobe - OEM Spec
Intake Duration - 165.7
Exhaust Duration - 182
Intake Lift - .2097
Exhaust life - .2303
Small Lobe - Delta Spec
Intake Duration - 184.5
Exhaust Duration - 161.5
Intake Lift - .2589
Exhaust life - .2101
Big Lobe - OEM Spec
Intake Duration - 202.2
Exhaust Duration - 182.7
Intake Lift - .2445
Exhaust life - .2305
Big Lobe - Delta Spec
Intake Duration - 206
Exhaust Duration - 184.4
Intake Lift - .2834
Exhaust life - .2588
This is a stage 1 set-up with emphasis on torque. There are way more specs I can upload but I think these are the major ones people care about.
Intake Lift - .2097
Intake Lift - .2589
Big Lobe - OEM Spec
Intake Lift - .2445
Intake Lift - .2834
Flip it really depends on what you want out of the cam.
Check this site out.
http://www.tildentechnologies.com/Te...rformance.html
-FLip
Camshafts sent
I sent them two camshaft one from a RA and the other from a Outlander which is the engine i have
Outlander camshaft has noticeable difference from the RA camshaft
I hope they get them by Friday
The guy told he'll be calling me as soon as he gets and measure the camshafts
I used the Scion Tc motor as sort of a baseline considering they have an aftermarket cam.
Few reasons:
-Large displacement SOHC motor.
-Variable timing motor
It came out awesome to say the least. pics will come later when I get home.
