Need advice on Custom Camshaft
Dyno Sheet
AFR
I'm gonna try and get a better AFR sheet. If I could add more fuel I could squeeze out a little more power. But right now it's well within safe parameters so I'm pretty happy, nonetheless Hack-man I need a new tune.
AFR
S-Dub,
I had the camera all set this morning and I thought I was recording, but apprently I was not. I have a 5 second video but I don't think it's adequate enough. I will take a better one my way home
As promised, a video of Mivec crossover with the new camshaft. It's quite noticeable.
http://www.youtube.com/watch?v=mKl7ThxlA_Y
Great mod for the price. I like the flat torque curve.
The high torque design may not not the best for bench racing but it's going to be the most fun for a street car. I can't wait to see a video of a full throttle pull.
I'll just say touge style in the Berkshire mountains.
The best indicator will be some runs down the strip tho.
I'll try and do a full pull later with the windows down. Car is not very loud with the Apexi WS2 muffler. Velo that bug looks effin badass. If it were not for my 6-3 240lb man frame I'd own one.
Hey ralliartize it what is your complete lists of mods? Because when you calculate it to a dynojet results depending on what type of dyno dynamics it's still lists at either 153.8(dynamic 1.1) or 169.2(1.0). Not baggin or anything just seems a little low if you have all the bolt ons. IMO anyway
Current Mods
AEM CAI
UD Pulley
Stock Header w/RRM v1 downpipe w/ 2.25 exhaust
Endeavor TB with thermal gasket
Hackish Reflash
Delta Cam
Ported Intake Mani
I do think the stock wheels with 205/55/16s killed some power numbers. And as much as folks say the stock header flows well, I honeslty believe I'm at the point where that is now a bottleneck. From my calculations converting to a dyno jet is about 184. 1 to 1.25. I do think a custom tune would def help quite a bit. The AFR shows me quite lean at low rpms and there are some random spikes as well.
