Need advice on Custom Camshaft
This is what happens when MIVEC activation is in the wrong RPMs
Blue graph shows MIVEC activation at 3800 RPM thats too low
Red shows NO MIVEC lobe
The sweet spot is in 4400 RPM
This is using stock camshafts with any aftermarket camshaft this sweet spot varies
good luck with your install...don't forget the valve adjustment. Sadly I'm still trying to work with Lanzer on getting his OEM cam to reach Delta. USPS is not being friendly right now. Ed what are the numbers on your cam?
When I talked with them they had 2 available for na...so I guess there's 3 them. This makes more questions than answers... I guess I gotta call Ken again..
or a walk around from engine bay to tailpipe!
