04-06 Ralliart Engine/Drivetrain (no forced induction)
Hard time holding an Idle
Old May 26, 2011 | 02:29 PM
Tim2s3's Avatar
I ran through a puddle that was pretty deep and it stalled the car. After 10 minutes it was finally able to start. But after a few days it started not being able to hold an idle. When it would idle it would be just above or right at 500. But whenever I put it in neutral it will go straight down and stall. I replaced the MAP and MAF sensors, cleaned the r and r egr valve. I have no idea what else it could be. Any thoughts?
Also when it is about to stall I can rev it to 4k rpms and it will idle just fine. Any help would be appreciated. Thanks
Old May 26, 2011 | 03:10 PM
CrAnSwIcK's Avatar
how deep was the puddle, and do you have a cold air intake?
Old May 26, 2011 | 07:12 PM
Tim2s3's Avatar
about 2 1/2 ft deep. Short ram intake
Old May 26, 2011 | 07:26 PM
CrAnSwIcK's Avatar
isn't 2 1/2 feet pretty close to your windows? and where on god's earth did you find a puddle that deep? and then decide to drive a car through it.
did it throw a code?
Old May 26, 2011 | 07:35 PM
Tim2s3's Avatar
There is a place in the road here on very high tides that is can get that deep. And I was kinda reatrded and thought hey I can make it... buuuuuut I couldn't. And it brought up a good bit of codes.
Old May 26, 2011 | 07:42 PM
Tim2s3's Avatar
PO102MAF signal low, PO113 IAT signal high, PO403 EGR Circuit Fault, PO106, PO131 02 signal low bank 1 sensor, PO13402 no act., PO171 fuel too lean bank 1
These are the codes that came up.
unfortunately not sure what all this means so if anyone else does please let me know!!! Thanks
Old May 26, 2011 | 07:59 PM
Raikiri's Avatar
2 1/2 feet? I'm already thinking you shorted something out and broke some sensors.
I'm surprised you didn't hydrolock
Old May 26, 2011 | 08:03 PM
Tim2s3's Avatar
Yea same here. I was surprised it even started up. But since it did I thought maybe it survived and I got lucky but I replaced the MAP and MAF sensors and cleaner the EGR valve and throttle body which helped a little but what do you think should be the next replacement? They said an EGR valve was 600 bucks? Seems a bit high?
Old May 26, 2011 | 09:38 PM
Raikiri's Avatar
im thinking your o2 sensors now
Old May 27, 2011 | 08:28 AM
RalliartN's Avatar
Did you clear the old codes so you could see which new codes pop up next?
Old May 29, 2011 | 02:10 PM
Tim2s3's Avatar
yea it was the pre 02 sensor showing fuel is too lean?
Fedetronchet
Dec 10, 2016 11:13 AM
mnewdigate
Lancer Troubleshooting
10
Apr 24, 2016 11:25 AM
SilverLanEvo
Jul 5, 2011 10:52 AM
xuder
Jul 16, 2010 10:45 PM
Aussie CG
Sep 7, 2005 01:04 AM
