04-06 Ralliart Engine/Drivetrain (no forced induction)
ralliart speed sensor or cluster problem
Old Jun 9, 2011 | 02:04 PM
crikboy's Avatar
Hi guys i have a problem my speedometer start going crazy up and down in the speed today it just stop working so i dont know what speed im going i put it to read the code and it said the speed sensor was bad but doesn't said witch one in or out.... i have a friend that know mechanic and he thinks is the cluster not working right .... how can i check if is the cluster or sensors .. and how do i check witch sensor is it , the input or the output thanks a lot in advance
Old Jun 9, 2011 | 02:33 PM
CrAnSwIcK's Avatar
not sure what you mean by input or output...but does the tachometer work still?
Old Jun 9, 2011 | 02:36 PM
crikboy's Avatar
no the speed dont move no more its on zero all the time and i talking about the
output shaft speed sensor or input shaft speed sensor i would like a way to check witch is bad or is the cluster is bad
Old Jun 9, 2011 | 06:40 PM
CrAnSwIcK's Avatar
as far as i know there is only one sensor. the speedo sensor is not on the output shaft, but actually runs off the differential. the other sensor on the transmission that is near the input shaft is actually on the reverse idler gear, and it switches your reverse tail (white) lights on. This is what leads me to believe the tach and speedo are run by the same sensor, let me verify the diagrams and see if i can confirm this unless someone else knows for sure.
That is why i asked if your tachometer (RPM) gives you an accurate indication.
Old Jun 10, 2011 | 05:53 AM
crikboy's Avatar
ok the RPM works fine give acurate reading the only one not working is the speed gage so I saw 2 sensors in the trasmision . RPM works fine so what sensor I need to change to fix the speed gage
Old Jun 10, 2011 | 08:52 AM
CrAnSwIcK's Avatar
Damn i always forget to ask, you have automatic transmission? that is why there is confusion. Auto trans has output shaft speed sensor, manual runs off the diff. either way, there should only be one sensor for speed/rpm, and one for reverse tail lights. By the way the diagram looks, the control circuit for your RPM and speed gauges receives inputs from your ECM and speed sensor, but the speed sensor i would assume is used to read both RPM and vehicle speed. So if the Tach works then it's probably you cluster that is busted, and it is more than likely an integrated circuit and can not be repaired easily on your own, or even separeted from the assembly for that matter. I would ask the dealer, only because you may want to retain an accurate odometer. otherwise you can just swap the cluster with one that works. I'll check if each gauge is an interchangeable module for you.
I can't find a separate part number for individual gauges, but someone else might be able to tell you, i've never had my cluster out.
Old Jun 10, 2011 | 09:02 AM
crikboy's Avatar
Originally Posted by cranswick
damn i always forget to ask, you have automatic transmission? That is why there is confusion. Auto trans has output shaft speed sensor, manual runs off the diff. Either way, there should only be one sensor for speed/rpm, and one for reverse tail lights. By the way the diagram looks, the control circuit for your rpm and speed gauges receives inputs from your ecm and speed sensor, but the speed sensor i would assume is used to read both rpm and vehicle speed. So if the tach works then it's probably you cluster that is busted, and it is more than likely an integrated circuit and can not be repaired easily on your own. I would ask the dealer, only because you may want to retain an accurate odometer. Otherwise you can just swap the cluster with one that works. I'll check if each gauge is an interchangeable module for you.
ok i have a manual transmission , so the sensor that send signal to the rpm and speed is that one in the transmission ?? Yeah is weird because my rpm works really good only my speed dont work at all and since yesterday the miles stop working too so ... So speed and mile dont work now .... You thinks is the cluster that one mess up?
Old Jun 10, 2011 | 09:10 AM
CrAnSwIcK's Avatar
now you got me thinking. since the control circuit in the cluster gets its input from the ECM as well, it's possible that the RPM is driven by a signal from the ECM, that is initially detected by another sensor, like crank angle sensor/cam angle sensor, or something like that...If that's the case, i would do what i originally suggested, pull the speed sensor (closer to the firewall, under the shift cables) check that the plastic gear is not damaged, and replace the sensor. the sensor is only like 50$ and i have a spare speedo gear and shaft for the sensor, i'll mail it to you for free if yours is damaged, it's a separate part from the sensor itself.
Old Jun 10, 2011 | 09:26 AM
crikboy's Avatar
now you got me thinking. Since the control circuit in the cluster gets its input from the ecm as well, it's possible that the rpm is driven by a signal from the ecm, that is initially detected by another sensor, like crank angle sensor/cam angle sensor, or something like that...if that's the case, i would do what i originally suggested, pull the speed sensor (closer to the firewall, under the shift cables) check that the plastic gear is not damaged, and replace the sensor. The sensor is only like 50$ and i have a spare speedo gear and shaft for the sensor, i'll mail it to you for free if yours is damaged, it's a separate part from the sensor itself.
the sensor you talking about is the one that has the white gears on the bottom ? Is the one in the transmission right... Do you have any link where i can purchase the sensor or i should go to the dealer and buy it ... Whats the spedo gear and shaft ???? Thanks in advance if i do need them your been so help full =)
Old Jun 10, 2011 | 05:32 PM
CrAnSwIcK's Avatar
Yes the one with the gear is the speedometer sensor, the sensor is seperate from the shaft/gear, here is the shaft and gear i have:
I'm actually home right now, and i'm using a lite version of Linux from a USB drive so i can't get you the part number for the sensor until monday, but mitsubishiparts.net had good customer service so far, i got all my parts there. You can get it from the dealership as well.
Old Jun 13, 2011 | 07:22 AM
crikboy's Avatar
hey man where do the shaft and gear in the pic go i have never seen that is the part of the sensor i need ?
Old Aug 10, 2014 | 01:06 PM
j_rivera's Avatar
crikboy I know this is an old thread, but I have the same problem. I have a 2006 Lancer ES m/t and the RPM's work fine but the speedometer and odometer aren't working. I've replaced the VSS but still no speedometer. Have you gotten yours fixed since this post?
Old Aug 11, 2014 | 06:14 AM
CrAnSwIcK's Avatar
I replied to your PM, with advice that was already in this thread...sorry.
anyway, RPM I don't think comes from the vehicle speed sensor so if, both are not working, I would think the problem is either in the wiring, or the cluster itself...
Old Aug 11, 2014 | 06:58 AM
crikboy's Avatar
Yes I did fix the problem by replacing the speed sensor but if you said nothing works maybe your cluster is bad
Old Oct 29, 2014 | 05:07 PM
MaxG_R//A06's Avatar
Update is availible for affected vehicule built (if my memory's good) before may 26 2005...can get you guys tech case number if you like
jdrames
Lancer Troubleshooting
Jun 3, 2016 02:38 PM
Evoguy!123
Apr 11, 2016 03:12 PM
Evo10HKS
Dec 9, 2015 05:01 PM
4G63_EVO
Dec 23, 2013 08:51 PM
05RalliartJake
Mar 22, 2013 07:23 PM
