04-06 Ralliart Engine/Drivetrain (no forced induction)
Limp mode
Old Oct 11, 2011 | 11:38 PM
d3hoppy's Avatar
Limp mode
Ok, so i have recently been stuck in limp mode... I have 2004 raillart, that i turbo charged, but i don't belive it is causing the problem. I have had a rough idle, and it is putting out a code : p2101 (Throttle Actuator Control Motor Magneto Malfunction)
First off i really don't know what that is, or what i need to replace.. Just please tell me what i would need to replace to fix it and i most likely will be able to get the job done. Should i replace the Throttle body it self ??
Old Oct 11, 2011 | 11:42 PM
d3hoppy's Avatar
Also have taken off battery to reset ecu, and it runs fine for about 15seconds before cel comes on, idles at about 1.5k and when put to the floor wont go past 2.3k rpm
Old Oct 11, 2011 | 11:54 PM
jr_2006IXMR's Avatar
Either your egr valve is bad, throttle body is dirty or need a new one, your battery could be bad...
Old Oct 12, 2011 | 04:10 AM
lanzerralliart's Avatar
EvoM Super Moderator
here are some search results for " P2101 "
https://www.evolutionm.net/forums/se...rchid=16511368
And do you have any pictures of that turbo'd Ralliart? We always like to see new ralliarts ,especially turbo'd ones
Old Oct 12, 2011 | 09:08 AM
CrAnSwIcK's Avatar
Lanzer, your link no worky for me
Old Oct 12, 2011 | 09:17 AM
try it now
Old Oct 12, 2011 | 07:00 PM
d3hoppy's Avatar
Ok, so im thinking its the little motor in the throttle body... It makes a little humming noise.. And when power is pulled from the battery it will work again, but for a short time, then kicks out again... So i'm going to order a new one, but my next question is will a 2007 eclipse tb work with my car?
And i've been wanting to get pics up but have little time, i hope to soon!
Old Oct 12, 2011 | 07:10 PM
yeah either the gt or the gs eclipse tb will work although the gt tb will be an upgrade
Old Oct 12, 2011 | 08:11 PM
d3hoppy's Avatar
Ok sounds good to me!
Thanks for the help guys!
MadBoost23
Lancer Engine Management / Tuning Forums
Jun 10, 2015 11:57 PM
Thatotherguy
Aug 2, 2013 11:09 PM
MarkChamorro
Jul 15, 2012 07:20 PM
2010 Rallihead
10
Dec 7, 2010 07:11 PM
Alchemist
Lancer Engine Tech
23
Jun 8, 2005 10:32 AM
