04-06 Ralliart Engine/Drivetrain (no forced induction)
What kind of spark plug wires does the RA have?
Old Apr 29, 2010, 09:29 AM
Buxnbaas's Avatar
I understand the noob desire for inexpensive upgrade, it almost makes it no fun that mitsubishi already installed the goods on the factory line. NGK iridiums, coil on plug ignition ect.
So maybe a thread on free or cheap starter projects might be fun. It'd be a good sticky. I myself am a new RA owner and have found myself in the same boat while surfing this site, thinking about plugs and wires and those usual cheap projects.
So how bout it people, should the moderators fire up a sticky thread like that?
Old Apr 20, 2012, 05:27 PM
AvenGerMK's Avatar
So is there any replacement for the ignition wires on the RA ??? Your talking about irridiums is nice and all but the NGK Type R's I believe are way better. Nology and skunk2 has nothing for the new RA any other company anyone has used?
Old Apr 20, 2012, 10:49 PM
CrAnSwIcK's Avatar
what? ignition wires? are you talking coils or the control harness?
NGK laser iridium are the OEM plugs, and the NGK part number is specified in ASA, and possible the manual. They are pre-gapped at 32 thou from the factory...you can throw any cheapo plugs in there and it will run, but most cheapo plugs are gapped at like 38-44 thousandths, and won't last as long...it's not a huge issue for normal operation, but it does obviously make a difference, and i see no reason to deviate from the manufacturer suggested plug, unless cost is an issue...there's probably a wide range of plugs that will fit/work...but the engine was designed and tuned to use a specific type...
Old Oct 13, 2012, 08:39 AM
Mitsuracer27's Avatar
Question
How long before you need to change the coils/wires if ever? I change my plugs every 60,000. FYI: Best ones are the OEM NGK Laser Iridium plugs for anyone wanting to know. part # NGK 3656
Old Oct 13, 2012, 11:56 AM
RalliartN's Avatar
"Scheduled maintenance service for emission control and proper vehicle performance":
Replace plugs at 105,000 miles, ignition cables every 5 years or 60,000 miles
Old Oct 13, 2012, 02:23 PM
CrAnSwIcK's Avatar
they must mean the coils... obviously you would swap a control harness every 5 years...
good info Nick, thanks buddy...i should change my coils then...
Ferp
Jul 11, 2016 08:07 PM
mshilto89
Lancer Engine Tech
Sep 30, 2011 09:14 AM
Nosmatix
Toronto Lancer Club
Aug 28, 2010 06:38 PM
sparkle_motion
Lancer Troubleshooting
Apr 30, 2009 01:38 PM
ralliart610
Apr 24, 2008 09:16 PM
Quick Reply: What kind of spark plug wires does the RA have?
