Car jumps accelerating from complete stop.
So, Ive been trying to figure this issue out for a few months. I've replaced the clutch, flywheel, and motor mounts and so far no luck at all.
The issue im having is when accelerating in first from a complete stop while letting out of the clutch the car just keeps jumping until the clutch is completely let out. What we did notice is the engine still moves a lot but not sure how normal that it since we already replaced the motor mounts. Every other gear works perfect when shifting and no other issues then just first gear. Starting in 2nd does the same issue just not as rough.
You could of continued this in the other thread as its still related
Please refrain from making multiple nearly identical threads, they clog up the forum, and requires all of the previous posts to be posted again.
So I took the car to a new mechanic and he said the OEM motormount purchased from the dealer isn't good. He said the engine rocks too much and is whats causing this problem. He re ordered a new one to see if the part was any different but it's not. He told me I need to find an aftermarket one? Any idea where I can find one?
Many vendors here have them. I suggest 80 level on rockwell scale if you don't want too much vibration felt inside the cabin. You only need to do the front one.
the flexane is around 40 dollars for a pint which is enough if your just filling the f/r and not removing the rubber Last edited by lanzerralliart; Apr 29, 2013 at 05:12 PM.
undressesitself
Sep 9, 2012 08:48 PM
