04-06 Ralliart Engine/Drivetrain (no forced induction)
Help?!? - 04 RA clutch issues & questions (pics)
Old Mar 26, 2018 | 03:14 AM
BlackWolf04RA's Avatar
Question Help?!? - 04 RA clutch issues & questions (pics)
Hey, I have a 04 RA i just bought with 100k miles. I got it for only $1,000 because guy said it makes a wierd noise.
has clutch problem , im hoping someone can pin point the problem for me , even thou im planning to replace the entire clutch system .
The car sounds perfectly fine when the cluch is in , when u realse the clutch u get alot of noise from it but not really a grind or a squeal its like somthimg hard clanking around in a dryer. Noise continues 1s gear through 3rd gear but will go away when goimg fast in those gears or higher gears.
Im planning to replave the whole clutch , not going for more performance thou im looking just to make it a little stronger than OEM , what all would i need i wantto replace EVERYTHING in the clutch all bearings and seals ????.
sorry for such a long thread in the middle of a complete overhaul thou , Thank You!
Fall of 2017
Fall of 2017
- BlackWolf04Ra
Old Apr 8, 2018 | 12:08 PM
jcmaz's Avatar
If you have a grinding issues at higher rpms, i think it may be a timing issue instead of your clutch.
On my Ralliart, the timing belt and balance belt was changed by the previous owner and was done wrong. The balance shaft is off and therefore the engine shakes at high RPM. My gears sounds like they are grinding after 5k rpm.
Do you know when the belts were changed?
phenem
Oct 11, 2008 08:47 PM
slickevo18
Sep 11, 2005 11:22 AM
Kwman
21
Jul 14, 2005 07:34 AM
4rcd6
May 13, 2005 11:50 AM
majestic lancer
Oct 13, 2003 07:02 PM
