RE: Failed o2 sensor
Old Aug 23, 2005 | 08:37 PM
Daddymac's Avatar
I'll do that when I go back.
Do you have any idea why the CEL light would just go away like that though?
Old Aug 23, 2005 | 09:36 PM
silversleeper's Avatar
its possible the car fixed the problem (the computer did heheh) so light would go out BUT the code will still remain in the computer i do belive.
Old Aug 24, 2005 | 05:56 AM
Daddymac's Avatar
I'm still going to have them replace the O2 though. They've already said its faulty.
Oh and I also called the dealer and found out the code. They said it was "Oxygen sensor circuit failure" But they also said that when they were testing the o2 it was intermitent which is probably why it cleared itself now.
Old Aug 24, 2005 | 09:04 AM
CF-Ninja's Avatar
take out your CEL bulb from the gauge cluster... its not like you need it anyways
Old Aug 24, 2005 | 11:05 AM
Daddymac's Avatar
I'll get right on that.
Old Aug 29, 2005 | 12:42 PM
Boston'sEvO-->8's Avatar
Yea I think my 02 sensors are both gone front and back...I have a simulator and I have a test pipe with catback and intake. Will the dealer cover them both? Or am I screwed?
Old Aug 29, 2005 | 12:44 PM
Daddymac's Avatar
Your screwed! You basicly changed the readings by fooling them. There is NO way they'll cover that.....
Old Jan 30, 2007 | 03:10 PM
YellowRalli's Avatar
So which PIN on the ECU do I connect the signal wire to form my A/F gauge, I have it hooked up now to pin #108 but it keeps setting off my CEL light.
Old Jan 30, 2007 | 04:06 PM
KreepaEvoX's Avatar
Mine was acting up a while back
When I had Injen, DP, Piping and Piggyback, because the mix was SOOOO Lean. Of course this was AFTERT the dealer flashed my ECU for a exhaust recall. Then I installed an A/F Meter and the sensor started reding like if it was faulty, the car misfiring and all. I took all the mods off for a month, reinstalled them, Even added up the RRM header, only then the CEL came back up...WEIRD thing, after 3 days it turned off and never came back up, only when starting, that way I know that the light aint faulty
ImsoevoX
17
Dec 8, 2012 11:39 AM
memphisraynes
Jul 6, 2012 12:53 PM
Evo1001
Jul 22, 2011 09:25 PM
vxevolutionxv
Sep 2, 2008 05:14 PM
vicbdn
May 10, 2006 08:41 PM
