what tranny fluid do you all use?
Old Oct 4, 2005 | 10:39 AM
quikkstylez's Avatar
just curious, im thinking of buying some BG synchroshift, any reviews? ive read some tutorials on how to change tranny fluid and im gonna attempt it once i buy some synchroshift, how hard is it?
and another question, at what mile intervals are we supposed to change tranny fluid? im too lazy to read the manual
Old Oct 4, 2005 | 10:59 AM
CarnEvil101182's Avatar
Wow, at least you admit your lazy. It only took me 12 seconds to find it in the manual.
Old Oct 4, 2005 | 01:09 PM
Myszkewicz's Avatar
I'm using GM Synchromesh in mine, and have been for 20,000 miles or so. No problems with it at all. A lot of the 'crunchiness' of the 1-2 shift went away.
It's pretty easy to change. Take out the fill plug first, then put a drain pan under the drain plug and remove the drain plug. Let it drain out, replace the drain plug. Slide drain pan up so it's under the fill hole. Insert funnel into fill hole, pour in two quarts, then top off with a third quart until fluid runs out of the fill hole. Replace fill plug. Done.
The fill plug is 17mm, and the drain plug is 22mm, IIRC. Maybe 23mm. It's been a while.
Old Oct 4, 2005 | 01:30 PM
otter's Avatar
EvoM Administrator
I'm using the BG Synchroshift II in mine, and I love it. Been in my car for about 19,000 miles. Always slides into gear smoothly.
Old Oct 4, 2005 | 01:50 PM
mojambo's Avatar
gm synchromesh here also, remember that you should ONLY USE GL4 rated tranny oil. THe GL5 stuff is too slippery and you will eat your synchros. GM syncromesh is great. I'm getting my clutch replaced as we speak and I'm getting a fresh batch of synchromesh put in.
Old Oct 4, 2005 | 01:51 PM
How often do you change your tranny oil?
Old Oct 4, 2005 | 01:52 PM
vikktorlv's Avatar
Tranny
Royal Purple
Old Oct 4, 2005 | 02:08 PM
thank god, i hate that, thats one of the main things im trying to get rid of at this point. thanks for all the info guys, will make another thread once i change it.
Old Oct 4, 2005 | 02:09 PM
superflyevo's Avatar
i used the bg syncro mesh
Old Oct 4, 2005 | 02:16 PM
evofan@scorp's's Avatar
I think it's recommended every 30K miles or so....super easy to do with a manual trans....with a auto, you have to have the exchange machine (t-tech at my shop).
Old Oct 4, 2005 | 04:38 PM
MitsuJoe's Avatar
24mm drain bolt.
Old Oct 4, 2005 | 05:04 PM
ModernRacer's Avatar
I use Royal Purple in mine as well, it's awsome!!!
Old Oct 5, 2005 | 11:48 AM
MitsuRalliArt's Avatar
Royal Purple is the only GL-5 I would consider using. I use it with RP 5w-30 in the engine. It is not uncommon for me to get 32 mpg. God bless synthetics.
Old Oct 5, 2005 | 05:26 PM
Ralliart@PDX's Avatar
royal purple
Old Oct 5, 2005 | 05:28 PM
vboy425's Avatar
BG Synchroshift, the best stuff on earth
