Fan constantly running loud
Old Dec 28, 2009 | 08:49 AM
  #76
RalliDew's Avatar
mine has been doing that for almost 30k miles it runs somewhat ok with the car on, never seen a temp boost but its funny when i turn the car off it revs up at me... only until the aux power cuts after the key is off lol
my mitsu said it would be a 50 doller part so maby ill doit but maby some heat shielding might be a good idea?
Old Jan 30, 2010 | 10:45 AM
  #77
floating doc's Avatar
I bought my 04 ralliart 2 weeks ago today from a Mitsubishi dealer. I just have one month of warranty coverage, and so I need to find out now if my fan controller needs to be replaced.
The fans are doing things that I've never experienced with electric fans, but I don't know if it's programmed that way or if it means that the controller is going bad. What it's doing could be considered normal, but I don't have any previous experience with this car to compare it.
After I shut off the engine, the fans will kick on about one second later. They will run for a few seconds, then shut off. They also don't always run when the engine is running, but I haven't had any problems with overheating. I've hardly been anywhere in the car, and haven't been in any traffic. It's also winter, so the weather is pretty cool. If there is a problem, I haven't yet had the car in a situation where it might be obvious.
As I've said, all of this could all be normal, but if something is wrong I need to know soon so I can get the stealership to pay for it.
Old Jan 30, 2010 | 10:58 AM
  #78
GearDownSon's Avatar
I would take it in guys. Its most likely the fan controller. The symptoms you stated are usually the beginning of the problem. It will then escalate to temp running a bit high during idle. This is a common problem between a lot of us.
An to be honest it is a REALLY easy part to replace. If the dealership is going to pay for it then cool if not i would consider doing it yourself.
Old Jan 30, 2010 | 11:27 AM
  #79
Raikiri's Avatar
^agreed. The part is fairly priced if you know where to go if dealership won't pay and install takes less than 5 minutes.
Old Jan 30, 2010 | 11:40 AM
  #80
Thanks for the fast reply. I've got to get it worked on anyhow, needs timing/bs belts. Got a quote of $250 for that from the dealer, so it's going in soon anyhow.
Old Mar 16, 2010 | 02:19 PM
  #81
MUNDO's Avatar
just got my part after 2 months >
how do you disconnect the cables? I know there's a clip..as in, you just don't pull it out....but how?
Old Mar 16, 2010 | 05:00 PM
  #82
Thomar's Avatar
looks like there is just one clip, facing the engine, that is holding the connectors together.
just push down on the clip and it should just unplug.
Edit: Sorry I gotta clarify... regarding the clip, dont actually push down on it. The top part of the clip needs to be moved toward the engine so that it 'un-clips'. Perhaps a flat head screw driver or something.
Old Mar 17, 2010 | 10:43 AM
  #83
This
Old Mar 23, 2010 | 08:08 PM
  #84
NJRalliart's Avatar
i had the SAME problem its the fan control module is fried out. I would start my car in 30 degree weather and the fan would stay on. And even after the car turned off the fan woudl continue.
Old Mar 28, 2010 | 06:39 AM
  #85
Dahkness's Avatar
my RA has been doin that for like 6 months, i def need to get another controler but there are no mitsu dealers round here
Old Mar 28, 2010 | 10:25 AM
  #86
Raikiri's Avatar
Talk to RussellM here he can help you get one. He's a vendor here
Old Mar 28, 2010 | 03:27 PM
  #87
lanzerralliart's Avatar
EvoM Super Moderator
Fix it a.s.a.p. It's like a ticking time bomb .... Tic toc tic toc, seriously
Old Mar 28, 2010 | 06:32 PM
  #88
I got mine through southwest Mitsubishi. VERY reasonable prices on oem parts. The service team is top notch.
Old May 24, 2010 | 03:01 AM
  #89
joenauta's Avatar
Originally Posted by Raikiri
sorry to bump. but does anyone have the part number for the fan controller? im trying to buy of the mitsubishiparts.net website since its a bit cheaper but cant figure out what the part number is. thanks guys
Mitsubishi Relay Part 1355A053
Old Jun 30, 2010 | 02:33 PM
  #90
nekkidlad's Avatar
I bought my 04 RA 5speed exactly 1 year and 1 month ago tomorrow w/ about 86000mi on it -now its at 110998mi- and since the day i test drove it the cooling fan kicks on and off every ten seconds on the dot and then kicks on or stays running -depending what it was doing- about ten seconds afer i shut the car off. ive taken it to the dealer 2 times so far for another issue and the writer says hey u runnin hot ot sumn that doesnt sound right...but ive had no problems and its never run hot, in fact the temp gauge stays about 1/4 inch under halfway... im not sure if thats a good thing or not but i beat the snot out of it daily and ive never had a problem...to be honest im not worried about replacing it anytime soon and im savin money to replace those dang leaking front AND rear struts i have first...
PS: I know its not related but does anybody else notice a kind of metallic clank and/or squeaking sometimes over potholes, tight turns or rough surfaces?...im assuming it has to do w/ the leaking struts and/or mounts...maybe even the sway bar links...(they're all oe after all)
