There's always something...Please help a guy out
Old Jul 13, 2012 | 10:09 PM
MarkChamorro's Avatar
Bump is there a way I could disassemble it so I can unjam it fully? Still having clutch issues...
Old Jul 14, 2012 | 04:53 AM
Canada_Comp's Avatar
Technically, the rod should travel more than that at full pedal stroke. It does take some force to push the rod back in, so that sounds normal.
Since at full pedal travel, the rod isn't moving as much, and you didn't indicate that you bled the system, I would bleed it first. Remember to bleed the clutch master cylinder bleeder first, as there is that "silly little plate" (see below link for what I'm talking about). Also, keep the reservoir filled all the way to the top. the clutch fluid intake is pretty high up on the reservoir (ref. https://www.evolutionm.net/forums/10219434-post41.html)
If you really want to disassemble it, here is my dissection thread: https://www.evolutionm.net/forums/04...intensive.html
a few more hours of sleep and I'll get on dropping my tranny... hopefully all goes well
Old Jul 14, 2012 | 08:27 AM
I believe my rod isn't traveling much since it is jammed, for example when the rod goes in the boot gets wedged in there and the rod will then stop traveling its full length. That's why I asked to disassemble it, but not fully disassemble, just get that damn boot out of there lol and good luck with the tranny, interested in what happens.
Also I will bleed the system, just looking for a little how to, although it is self-explanatory...just don't want to mess up
Old Jul 14, 2012 | 10:29 AM
RacerX-Ralliart's Avatar
When you push the rod in you should be able to move the fork and get the rod out of position to remove the boot
Old Jul 14, 2012 | 10:37 AM
Thank you sir, and the fork ? Explain that one part lol I mean I'm sure I'll get it if I look but just to make sure
Old Jul 14, 2012 | 10:48 AM
The part that goes to the trans That the rod pushes on..
Old Jul 14, 2012 | 11:48 AM
Well now it won't push in even if I push hard, this is after I adjusted my clutch pedal. Idk if that happened because I over tightened or not. But back to the pedal adjustment
Old Jul 14, 2012 | 10:20 PM
my findings are posted: https://www.evolutionm.net/forums/04...way-out-4.html
Fireescape
Jul 4, 2016 11:18 PM
vaflyboi757
Dec 18, 2015 10:27 AM
RawrImAMonster
20
Jan 4, 2013 09:24 AM
tsitalon1
57
Mar 6, 2012 10:37 PM
tsi1991awd
Feb 2, 2010 07:34 PM
